Since all new smartphones come equipped with powerful cameras, it’s normal for mobile users to have large photo collections on their phones. What if those images get deleted or lost? Don’t worry, there are numerous tools that can help you get them back instantly.
Free download DroidKit to selectively recover all or part of your photos easily.
New apps for data recovery on mobile phones are launched regularly, and this market is highly competitive, to say the least. For this reason, choosing the best photo recovery app for Android mobile phones could be the trickiest part. That’s why we prepared an overview of the apps that are currently regarded as the most effective for the aforementioned purpose of reclaiming lost photos.
Android Photo Recovery
Let’s take a look at some of the best Android photo recovery apps:
See Also: Best Recovery App for Android without Root >
DroidKit is a complete solution for Android phone rescue. And it is really good at fixing various types of annoying issues that Android can’t resolve on its own. With its “Recover Lost Data” function, you can quickly recover deleted WhatsApp, photos, contacts, etc. to your phone or computer without root.
If the data were stored on the SD card, you can recover the deleted data from SD cards, photos, videos, music, etc. are all supported. In a word, it can recover any data you need from an Android phone. Check some of its main features below.
To recover lost photos on your Android, you need to follow the steps below:
Step 1. Once you have downloaded DroidKit on your computer, launch it and click “Recover Lost data” and choose “Quick Recovery from Device”.
Choose Quick Recovery from Device from Recover Lost Data
Step 2. Connect your device to the computer, select the data type you need to recover and click the “Start” button to continue.
Select the Data Type that You Want to Recover
Step 3. Preview all your data and select “Photos”, then, click “To Device” or “To PC” to save photos on your phone or computer. After that, just wait for the tool recovering photos for you.
Choose Deleted Photos and Recover
Another popular choice as the primary data recovery tool for mobile users is PhoneRescue for Android, it can perform the recovery process with success in most instances. Up to 31 file types are supported, including deleted text messages, app data, contacts, videos, WhatsApp, Line, etc. Let’s see some of its main features below.
Follow the steps below to recover photos on Android:
Step1. Free Download PhoneRescue for Android on your computer. Launch it and connect your Android phone to the computer via a USB cable. Here we take Samsung as an example.
Connect Your Android Device to the Computer
Step 2. Select “Photos” and click on the “Next” button to scan those deleted files.
Choose Photos and Click Next
Step 3. Preview and select the photos you would like to recover. Then, click “To Device” or “To Computer” to save them. After that, just wait for the tool recovering photos for you.
Restore Photos to Phone or Computer
This is another well-known app that works perfectly well on any OS or phone model. It can reliably return the photos you erased, and it’s not hard to learn how to take advantage of its advanced features. Dr. Fone is definitely one of the Android photo recovery apps you can trust with a crucial task and feel confident about your chances for success.
Dr.Fone – Data Recovery
Pros:
Cons:
If you are looking for a simple tool that will provide you with an extra layer of security, DiskDigger might be the right answer for you. It has the capacity to find deleted files in multiple locations, and this versatility can be very valuable when you are trying to salvage your content after a disaster.
Recover Photos with DiskDigger
Pros:
Cons:
Those who want nothing but the best photo recovery for Android mobile should learn a bit more about FonePaw. This software can fix the problem with lost photos in a number of different scenarios, even if your device has broken down. This puts FonePaw among the handful of Android apps that are truly worth downloading.
Recover Photos with FonePaw
Pros:
Cons:
This is another simple app you can download from Google Play Store without having to pay for it. Undeleter can quickly scan the phone as well as memory cards and discover files that you previously deleted. With this tool, you can find every image that you feared was lost forever.
Recover Photos with Undeleter
Pros:
Cons:
With so many cool and effective Android photo recovery apps at your disposal, you have no reason to panic if some of your photos disappear from the device. Just pick the tool that is the most optimal for the type of issue you are experiencing, and follow the instructions to get your pictures back. DroidKit and PhoneRescue for Android are two nice options for all Android users. Download and give them a try!
