If you’re stuck in google photos not showing all photos problem, luckily, you can get 9 ways to solve this issue. Moreover, you can get an extra tip to recover those photos disappeared from Google Photos.
It’s without a doubt that Google Photos is one of the best cloud storage facilities for storing photos on the net. This platform acts as an alternative for your Android gallery. Google Photos provides enough space to export your desired images for future reference. It’s a simple platform, reliable and trustworthy. Thus, users don’t have to worry about security issues.
Getting your photos on Google Photos is pretty straightforward. However, recently, there have been reports of Google Photos not showing all images. Does that sound familiar? If so, and you need a solution, we are here to help you.
Here, we will share a troubleshooting guide with official solutions to fix Google Photos not showing all photo issues. Without delay, let’s get started!
Google Photos won’t show all photos for several reasons, however, here are the prominent ones:
With the 9 official solutions provided below, you can fix Google Photos app not showing all photos issues effortlessly:
As we all know, the internet is crucial for Google Photos to function properly. Connecting your mobile or computer system to a stable data network would help Google Photos fetch all the photo data stored on its server. We recommend that you use a stable WiFi connection or mobile data.
Since the cache is one of the problems causing Google Photos to misbehave, clearing it often would help resolve the issues.
To clear the cache on Google Photos, apply the instructions below:
Clear Google Photos Cache
If you have the backup and sync options disabled for Google Photos, you cannot access the whole photos on the server. A simple technique to resolve this is- enabling backup and sync options. Once done, you can view all the photos on Google Photos without stress.
Enable backup and sync options by following the steps below:
Turn on the Sync Option in Google Photos
Here is a simple guide to doing that:
Make Sure that You Have Enabled the Folders to Upload
Sometimes Google Photos images are accidentally moved to archive and trash folders. A quick check on these folders can fix the Google Photos not showing all photos issues you are currently experiencing.
Here is the simple procedure to check the archive folder on Google Photos:
If after checking the archive the issue persists, follow the stepwise guide below to check the trash folder:
Have you granted Google Photos access to your SD Card? If not, there is a possibility you won’t find your entire photos on the cloud storage facility. A simple way to fix such an issue is granting Google Photos permission to access the SD Card.
The procedure involved is quite simple. Follow the instructions below:
Enable SD Card Access
Uploading photos manually to Google Photos is another helpful solution you can use to fix Google Photos not showing all images. Here is a simple guide you could apply to resolve the issue on your mobile device:
Google updates it’s apps, including Google Photos, frequently to clear the software bugs and temporal glitches that are affecting the previous version. So you must update related apps on your device.
To update the Google Photos app, launch the Google Play Store or App Store on your device, and enter Google Photos in the search field. Hit the Enter button to proceed. Once done, a new screen with the Google Photos app will come up. Click on the corresponding icon to download and install it.
This is the last solution to fix Google Photos not showing all photo issues on our list. The solution recommends that you access Google Photos via the website instead of using the app.
If you still cannot find the photos that are not displayed by the above methods, then they are probably missing. In this case, you may be wondering how to get those disappeared photos back.
DroidKit is exactly what you are looking for in 2022. With DroidKit, you can easily find, preview, and recover deleted photos from your Android phone. Not only the photos in Google Photos, but also any deleted or lost photos on your Android phone can be retrieved through DroidKit.
Now, install the latest version of DroidKit and check its main features on Android data recovery.
Step 1. Launch DroidKit on your computer and connect with your Android Phone. Choose Quick Recovery from Device.
Step 2. Select Data to scan deeply from your Android phone, here you can choose Photos only or all types of data.
Select and Scan Photos
Step 3. Make sure you’ve connected your Android phone, and click Start afterward. Then DroidKit will start to scan the deleted photos on your Android device. When the scanning completes, you will see the deleted photos on your Android phone. You can either select photos to recover To Device or To PC.
Select Deleted Photos to Recover
Now that you have our troubleshooting guide to fix Google Photos not showing all photos, kindly select one and apply. You can apply all if one isn’t yielding results. All solutions provided are cost-free and simple to implement. You don’t have to visit an Engineer to help you fix Google Photos not showing all image issues. You can always fix it yourself. Try the solutions out now!
