If you are curious about Where your contacts are stored on Android, we’ll show you how to find out the Android contacts in this article. As a result, you can effortlessly manage phone contacts or recover contacts whenever needed.
DroidKit allows you to recover deleted photos from the Android gallery without backup. You can use quick recovery without root or deep recovery.
Unlike iPhone users, Android users must store their contacts in a slightly different manner, but it is not difficult. Android phones allow you to securely and safely store phone data and your contact lists on your Android devices. For example, you can choose to store your contacts on Google Cloud, internal storage, or your SIM card, etc. for a backup. So, you can even restore your contact list in case of an emergency or if you have lost or broken your Android phone.
However, where are contacts stored in internal storage? How can you export contacts backup? So, in the forthcoming parts of this article, we will be discussing where are contacts stored on Android devices, and how to export contacts from Android phones.
Android provides internal storage for you to put data into it, which is always available on all devices. If you are searching for your contact list in the internal storage of your Android device, but can’t find the exact location unless your Android device is rooted. Do not worry at all.
All the stored contacts save in a specific location and you can easily find them by entering that location like you find your valuable pictures in your phone’s gallery. In order to see your contact list in the internal storage of your Android device, you just need to enter: /data/data/com.Android.providers.contacts/databases/contacts.DB.
Additionally, all the stored contact are not saved with the VCF file format but you can find them as SQLite 3 files, that are not at all easy to open. To open this specific file format, you need a program such as SQLiteman and DB Browser.
Where are Contacts Stored in Internal Storage
Speaking about storing your Android contacts on a SIM card, there are a lot of people who have this confusion if they can store and find their contact on the SIM card or not. But it is quite feasible and the most effective way to secure all your contacts.
By following the further steps, you will be able to access and manage your contacts on your SIM card conveniently:
Export Contacts to SIM Card
Further Reading: How to Retrieve Contacts from SIM Card >
In the present era, almost everyone relies on the internet, and in order to secure their database, they need cloud storage. Storing your Android contact in Google cloud storage is quite easy and convenient. And it’s not just about your contacts, but you can synchronize almost every data information in Google cloud storage.
Like every user, you also have 15 GB of cloud storage to access from Google and you can store your contact there. In order to find your valuable contact list and to manage it as well, you are required to follow the instructions mentioned further:
Sync Android Contacts with Google
Further Reading: How to Fix Contacts Disappeared from Android >
Apart from any features available in your phone, phone contacts are the most crucial thing in your Android phone. It would be very difficult for you if you lose your contact list. In order to secure your contacts, you are required to manage and export them in the following ways:
Whether you want to export your contacts to vcf, html or other formats, DroidKit always can be the right choice. Not only that, you can choose any path you want to save your contacts in, depending on your needs.
Besides data manager, it is a complete Android solution that provides you with data recovery and data extractor tool. You can recover deleted contacts, extract contacts from your Google account, transfer contacts from a broken phone to computer, etc.
Now, just follow the steps below to learn how to transfer contacts from android to laptop/computer:
Step 1. Once you installed DroidKit, open it and choose Device Manager under Data Manager.
Choose the Device Manager
Step 2. Connect your phone with USB > Choose Contacts data type.
Step 3. Preview all of your contacts and select them > Click the To PC button.
Choose Data You Want to Transfer
Step 4. For the first time transferring data to a PC, you need to confirm the formats and paths.
Step 5. Wait for the transferring process to be finished, you will get the Transfer Complete page. You can click View Files to check them on your computer.
Data Transferred Successfully
If you are a Samsung Galaxy user, you can export and manage your contact list easily. To manage your contact list on your Samsung Galaxy phone, you can follow the instructions below:
The most convenient method for exporting and managing your contact list on your Samsung Galaxy phone is to use the Google cloud. You simply need to follow the following steps:
Android phones are the most popular in the current market, and a contact list is an essential component of each phone, and you must keep your contacts if you do not want to lose them. To protect contacts, you can use DroidKit to save them to computer. What’s more, even if your contact information is accidentally lost, DroidKit can help you get it back in time.
