Searching for a way to transfer files from Android to PC wirelessly? Read on this guide to see how to transfer files from Android to PC wirelessly. 3 different methods will be shared here.
Transfer Files from Android to PC Wirelessly
USB driver on your computer not working, have no USB cable around, or Android Files Transfer no device found? No matter what the reason is that causes you to search for another way to transfer files from Android to PC wirelessly, the practical methods in this tutorial may be helpful to you.
Here in the following tutorial, we have come up with a detailed guide on how to do wireless file transfer from Android to PC. You can go through all the methods below firstly, and then choose the one best suits your needs.
Here are three different methods by that you can do Android wireless file transfer. Let’s check it now.
Transferring files wirelessly between your Android and PC does not need to be a tedious task. Over Wi-Fi, just a simple drag and drop of the files, and they will be transferred from your phone to other directions including the computer effortlessly. AnyDroid is just the exact Wi-Fi file transfer tool recommended by millions of users. Below are its incomparable features on Wi-Fi file transfer.
Now, free Download AnyDroid on your PC first, and then follow the steps below to transfer files from Android to PC wirelessly.
Launch AnyDroid on your PC > Go to Google Play Store or other app stores to download AnyDroid app on your phone > Open it > Tap on Scanning QR Code to scan the QR code on your PC.
Connect iPhone and PC with Wi-Fi
Choose Content to Computer mode to transfer files from device to PC.
Choose Transfer Mode
Select the file categories you would like to transfer to your PC > Click the Next button to start the process.
Bluetooth file transfer is one of the most common methods to move photos, videos, or other kinds of files from Android to PC without the need for a USB cable or Internet connection. However, it is not the easiest methods to finish the task. Also, it is limited to file types and requires a long procedure.
From your Android, go to “Settings” > “Bluetooth” and turn Bluetooth on. Ensure your Android is set to be discoverable via Bluetooth. From your PC, go to “Start” > “Settings” > “Devices” > “Bluetooth & other devices”.
Your device should show in the list of devices > Select the “Pair” button next to it. Your device and PC will show a passcode. Ensure that the codes match on both your devices. Tap “OK” on your Android and “Yes” on PC.
On your Android Phone:
Select “Send or receive files via Bluetooth” from your Android > Choose “Send files” > Select your PC > “Next” > “Finish” > “Browse” > Choose the files you want to send to your PC > “Open” > Tap “Next” to send it > Finish.
On your PC:
Select “Send or receive files via Bluetooth” from your PC > Choose “Receive files” > Select the location to save the files to > Finish.
The last way you can try to transfer files from Android to PC wirelessly is to use some third-party cloud services, like Google Drive, Dropbox, OneDrive, etc. all files saved to cloud service are synced instantly with all your devices that access the service.
To transfer files from Android to PC, you just need to view the files and touch the Share icon. Then, choose one cloud service to share the files to your PC. Or open the cloud service app and upload files to sync the files to PC. Here, we will take Dropbox for an example. Now, let’s see how to transfer files from Android to PC with Dropbox.
Launch Dropbox on your Android phone > Click on “+” icon at the bottom of your screen.
Click on Add Icon
Choose “Upload photos or videos” and then select the files you want to transfer to your PC > Click on “Upload” and the selected files will be uploaded to your Dropbox account.
Upload Files
Go to dropbox.com and sign in with your Dropbox account > Download the files you just selected from your Android phone.
There is also a way that can transfer files from Android to PC using USB cable successfully. DroidKit is a complete Android solution that helps you to transfer files between Android and PC, which can be the best alternative for wireless file transfer from Android to PC.
Besides, it allows you to recover deleted files on Android or a broken phone, bypass FRP lock, remove any phone’s screen locks, etc. No matter what issues happen on your phone, DroidKit will save you from troubles at the very first moment.
Let’s go first to preview how to transfer files from Android to PC with USB cable:
Get the latest version of DroidKit on your Windows/Mac > Connect phone to PC and click on Data Manager.
Choose Data Manager
When you click on Data Manager, choose Export Content and the data types that you want to export.
Select Data You Want
Here we take photos as an example. When you preview all photos on your Android, select what you want to transfer and click To PC button.
Transfer Photos to PC
After transferring process is completed, click View Files and you can check what you’ve transferred to PC as below.
View Transferred Files on PC
That’s about how to transfer files from Android to PC wirelessly. AnyDroid is a way for you to wirelessly transfer Android to PC without any medium services. You can give it a try now! If you will meet any problems while trying the above ways, feel free to leave your comment below and we will reply to you soon. Lastly, if you find this guide useful share it to help more Android users who are searching for a way to transfer files to PC wirelessly.
