Want to transfer files from Android to Android via WiFi but don’t know how? Here in this article, just check on this article and know how to transfer files between Android devices using WiFi.
“Sometimes I want to share some photos and videos with my friends but it can be quite troublesome to transfer files from Android to Android with USB cables or Bluetooth. Is there any quick method to transfer files from Android to Android via WiFi instead of connecting with a cable? ”
A user from Android Community
For this purpose, AnyDroid is definitely an option to go if you want to transfer files from iPhone to iPhone via WiFi. Within simple clicks, AnyDroid can help you transfer all kinds of files from Android to Android via WiFi connection. Let’s move on and know detailed steps to make it.
As an impressive Android data transfer tool, AnyDroid is fully capable of transferring files from Android to Android via WiFi easily. Here let’s check some main features of this tool:
Firstly, you need to free download AnyDroid to your computer and then follow the steps below to transfer files from Android to Android via WiFi.
Step 1: Run AnyDroid on your computer and then free download AnyTrans app to your Android phone. You can get it via https://anytrans.site/ or Google Play.
Step 2: Make sure your computer and two Android devices are connected to the same WiFi network and then scan the QR on the computer screen with your AnyTrans app on Android phones.
Step 3: Then select the files you want to transfer from Android to Android and click on To Device button to start moving files from Android to Android using WiFi.
That all about how to transfer files from Android to Android via WiFi by AnyDroid. In addition, you can also transfer files from iPhone to Android with AnyDroid. Now just get it to your computer and have a free trial >
