How to Transfer Data from Samsung to Xiaomi Successfully
If you have bought a Xiaomi android phone and now you want to transfer data from Samsung to Xiaomi, but the thing is how you can transfer this data. Multiple options can be useful for you to transfer the data from your Samsung mobile to Xiaomi mobile.
Author Avatar Joy Taylor Last Updated: Oct. 17, 2023
Read in: Read This Article in
Deutsch
Now-a-day, people want to use the latest smartphone launched in the market. Regardless of the brand, they buy the smartphone that is currently launched or has some new features. If you are a Samsung user and now you wanted to switch to a Xiaomi phone, then the most basic thing you must be worried about is the data of the phone.
If you try to transfer data from Samsung to Xiaomi mobile using the old ways, then it could take a huge time and be a lengthy process. Here we have discussed some of the ways that you can use to transfer data from Samsung to Xiaomi mobile. Stick to the post to get the desired solution for the data transfer process.
Transferring data from one phone to another is a lengthy process, as our old phone may have a lot of stored data in it. But to help you out with this we have searched for some viable options to transfer data from Samsung to Xiaomi. There are some methods mentioned below that can help you transfer data from your Samsung phone to Xiaomi.
Transfer Data from Samsung to Xiaomi via Email
One of the most prominent options to transfer data from Samsung to Xiaomi is forwarding it by email. You can send the data of an optimum amount to the desired sender.
Here are some steps that can help you to transfer data from Samsung to Xiaomi mobile.
Step 1: On your Samsung phone, log into your mail.
Step 2: Select the data you want to transfer to your Xiaomi mobile and upload it as an attachment to your mail. Send the mail to the desired mail ID.
Transfer Data with Email
Step 3: On your Xiaomi mobile, log in to the mail ID to which you have received the mail or from which you have sent the mail.
Step 4: Open that particular mail on your phone, and download the attachment.
If the attachment that you added to the mail is larger, then we will recommend you to connect your phone to Wi-Fi before downloading it. Also, some data types are not supported by the mail.
Transfer Data from Samsung to Xiaomi via AnyDroid
Want a one-click way to transfer data from Android to Android? We recommend you giving AnyDroid a try. This professional Android data manager makes transferring data from one Android device to another much quicker and easier. It supports transferring a lot of types such as photos, contacts, messages, music, etc.
The best thing about AnyDroid is that you can transfer data selectively from Android to Android. Moreover, you can even use it to transfer content between computer and Android, and between iPhone to Android.
Let’s check out how to transfer data from Samsung to Xiaomi with AnyDroid.
Step 1. Connect Devices to PC
Free download AnyDroid and Launch the program on the desktop > Connect your devices to the computer with USB cables or under the same WiFi.
Step 2. Choose Android Mover
Click on the Android Mover option > Tap on the Content to Android option.
Choose Android Mover Function
Step 3. Select and Transfer Files
Follow the instructions on the screen, you will see all the data on your Android device have listed here. Select all or choose the one you want to transfer. Minutes later, AnyDroid would complete all the data transfer from Samsung to Xiaomi.
Choose Category and Click Next
Move Data from Samsung to Xiaomi via Bluetooth
Bluetooth is the most basic option for mobile to transfer data from one to another. It is one of the in-built features of a mobile that helps in the wireless connectivity of a phone for transferring data. To transfer data from Samsung to Xiaomi phone, Bluetooth is a feasible way.
Follow the below steps to get to know how to transfer data from Samsung to Xiaomi.
Step 1: Turn on the Bluetooth on both the Samsung and Xiaomi devices. Keep your both phones close enough to get connected.
Transfer Data from Android with Bluetooth
Step 2: Pair both the devices entering the code on another phone that is provided on one phone.
Step 3: Select the data that you need to transfer from your Samsung phone to the Xiaomi phone.
Step 4: Send the data and click “Accept” to receive it on the Xiaomi phone.
Taking your one phone far away from the other can affect or lose the connection between them.
Copy Data from Samsung to Xiaomi via Share Me
Share Me is an app that is powered by the Xiaomi company, which makes it secure to use. It is one of the easiest and quickest apps that you can use to transfer data from Samsung to Xiaomi.
Step 1: Download and Install the Xiaomi app.
Step 2: Start the app on your Samsung phone and click on “Send“.
Step 3: Select the data that you want to transfer from your Samsung phone to Xiaomi.
Transfer Data via Share Me
Step 4: Open the app on your Xiaomi phone and tap on the “Receive” option.
Step 5: Scan the QR code from the sender phone that is available on the receiver phone.
Step 6: After establishing the connection, the transfer of data will start automatically.
Approve all the app permissions that are required and turn on the Bluetooth, Wi-Fi, and location option on both of your phones. Don’t take any of your phones away from others.
After buying a new phone, the main issue is to transfer the data from one phone to another. Well, we have discussed here with you some of the methods that can help you to transfer data from Samsung to Xiaomi quickly with the ease of a few clicks. Also, if you want to not only transfer data between Android devices, but also manage your Android devices in general, download AnyDroid and give it a try!
