When you switch to a new Motorola phone, the important thing is to successfully transfer data from the old device to the new one. In this article, we have discussed 5 viable ways to transfer data from Motorola to Motorola. Just read and choose one you like.
If you switch to a new Motorola phone, just free download DroidKit to 1-click transfer data to your new device. All data types can be transferred, like photos, messages, videos, contacts, etc. Transfer in minutes or even seconds, and no skills are needed. Most importantly, it supports all Motorola or other Android devices.
Getting a new Motorola phone is a major flex; however, the main issue arises when it’s time to transfer data from your old phone to the new one. You’ll find many ways that tell you how to transfer data from Motorola to Motorola; however, not all of them have a high success rate. Some might cause you to lose your data entirely or cause issues with your device.
Therefore, to save you from all this hassle, we have put together 5 tried and tested ways to transfer data from Motorola to Motorola. Just read this article to learn about these ways and choose the best one for you.
Bonus Tip: Below are some other tips about Motorola. Click and read if you need.
Is there an app to transfer data from Motorola to Motorola? DroidKit – Android Phone Toolkit is such a Motorola data transfer app you cannot miss. It is a complete Android solution that offers multiple troubleshooting features, like managing and transferring data on Android devices, removing lock screen passwords, upgrading and reinstalling OS, recovering lost data, fixing system issues, and more.
As a powerful data management tool, DroidKit allows you to easily view, manage, backup, and transfer all the data on your Android device. With this tool to transfer and back up data, you no longer have to worry about data loss or data transfer problems when switching phones. You can learn more about DroidKit’s data management features below.
Of course, you can also use DroidKit to transfer data from Android to Android, Android to computer or vice versa, and even iPhone to Android.
Now you can free download the latest version of DroidKit. And below are the simple steps to transfer data from Motorola to Motorola safely and securely:
Step 1. Run DroidKit on your PC or Mac. Then, select Data Manager and choose Android Mover.
Choose Android Mover
Step 2. You will see two modes on the following screen. Choose Android to Android.
Step 3. Then, you need to connect your devices to the computer and click Migrate Now.
Click on Migrate Now
Step 4. You will see some data types. You can transfer all of them or only choose what you want to transfer.
Select Data You Want to Transfer
Step 5. It will start transferring data to your Motorola phone, please wait for a while.
Data Transferred Successfully
Therefore, you can successfully transfer data from Motorola to Motorola in just a few easy steps.
If using a third-party app is not your cup of tea, you can transfer data from Motorola to Motorola via Motorola Migrate. Motorola Migrate is an app designed specially for Motorola data transfer.
However, the first question is: Is Motorola Migrate still available? Unluckily, you cannot use Motorola Migrate on devices running Android 6 and above, because Motorola company has restired this tool a few years ago.
But if your Motorola phone is still running Android 2.2 to Android 5.1, then you can use this Motorola transfer app. For this method to work, you must install Motorola Migrate on both devices. Here’s how to transfer data from Motorola to Motorola.
Step 1. Download Motorola Migrate on your new and old Motorola phones.
Step 2. Open the app on your new Motorola phone, select your old phone as the source, and tap “Start.”
Step 3. Next, launch the app on your old Motorola phone, select all the data you want to transfer to the new device, and tap “Start.”
Step 4. A QR code will appear on your old phone; scan it on your new phone to connect the devices and begin the transfer process.
Step 5. The data will take a few minutes to be transferred from your old Motorola phone to your new one.
And that’s how you can transfer data from Motorola to Motorola using Motorola Migrate quickly and easily.
Another straightforward way to transfer data from Motorola to Motorola is via Google backup. This method involves syncing both your Motorola devices with the same Google account. Here’s how:
Step 1. On your old Motorola phone, go to “Settings > Backup & Reset.”
Step 2. Add your Google account and turn on the toggle for “Back up my Data.”
Turn on Back My Data Option
Step 3. Go to “Settings > Account > Add Account” on your new Motorola phone and add the same Google Account you used on the old phone.
Click on Add Account
Step 4. Turn on the toggle for all the content you want to transfer.
Step 5. Tap on the 3 dots in the upper-right corner and click “Sync Now.”
Tap Sync Now
Step 6. All the files backed up to your Google account from the old phone will automatically be transferred to your new phone.
You May Like: If you want to restore your Google backup, you can read How to Restore Android Phone from Google Backup >
How to transfer Motorola to Motorola? If you don’t have too many files to transfer, you can try to use Bluetooth. However, this method only works for images, videos, and documents; you cannot transfer messages or contacts. Therefore, if you only need to transfer media files, you can Bluetooth them to your new Motorola device. And here is how to transfer data from Motorola to Motorola via Bluetooth.
Step 1. Turn on Bluetooth on both your Motorola devices, and pair them with each other.
Step 2. On your old Motorola phone select the images, videos, and documents you want to transfer on your old Motorola phone.
Step 3. Now tap “Share > Bluetooth” and click on the paired new Motorola phone.
Tap Share via Bluetooth
All your selected data will be transferred to your new Motorola phone in just a few minutes.
You can also use Google Drive to transfer Motorola to Motorola, but as it only works for music, videos, photos, and documents, you can’t move messages, calendar entries, or contacts. So please check what you want to transfer and read on to learn how to transfer data from Motorola to Motorola in this way now.
Step 1. Download Google Drive on both Motorola devices.
Step 2. Open Google Drive on your old phone, tap “+ > Upload,” and select the media files you wish to upload.
Upload Files to Google Drive
Step 3. Now open Google Drive on your new phone, and sign in using the same Google account. All the uploaded data will be accessible via Google Drive on your new Motorola phone.
Now that you know all 5 ways to transfer data from Motorola to Motorola, let’s answer some common queries.
Can’t Miss: Want to recover data from Google Drive? Here is the guide 5 Ways to Recover Permanently Deleted Files from Google Drive on Android >
Hope you have known the ways to transfer data from Motorola to Motorola. And here we will answer some other related questions.
Q. Is Motorola Migrate still available?
Motorola Migrate is no longer available, as Motorola retired it in 2015. Therefore, Motorola devices with Android 6 or higher won’t be able to use this feature. However, you can use other alternative methods to transfer data from Motorola to Motorola, like Bluetooth or Google backup.
Q. Does Motorola have a data transfer app?
Since Motorola Migrate is no longer available, there is no data transfer app by Motorola as of now. But that doesn’t mean you cannot transfer your data from Motorola to other devices; you can use the Samsung Smart Switch app for this purpose.
Q. Will Smart Switch work on Motorola?
Although Smart Switch is a data transfer app by Samsung, you can install and use it on your Motorola phone. It works for transferring data from Android to Android and Android to iOS.
If you’ve got a new Motorola phone and want to transfer data from your old phone to the new one, we’ve got you covered! In this article, we have discussed 5 different ways to transfer data from Motorola to Motorola safely and quickly. And compared with other methods, DroidKit can help you manage and transfer your data in a much easier and quicker manner. And it has no restrictions on Android OS versions. So just get DroidKit for free and have a try now.
Have you ever transferred data from an old phone to a new one? Which method did you use, and which was the fastest? Let us know in the comments.
