If you switch a new Samsung phone from LG, then you must want to know how to transfer data from LG to Samsung. In this in-depth article, we offer 5 easy and quick methods to help you transfer data from LG to Samsung.
We’ve all been there. Sometimes we buy a new smartphone and want to transfer all of our contacts, music, photos, and more from the old phone to the new one.
But then you realize that your old phone is an LG and your new phone is Samsung, so how do you get that data onto your new device?
There must be a way around this, right?
If you’re looking for easy ways to transfer your data from LG to a Samsung device, this article can help!
Here are 5 different methods that are effective and easy.
Have you bought a new phone and still wondering how do I transfer all my stuff to my new Samsung phone?
Don’t worry! We have got you covered. As crazy as it may sound, using AnyDroid, the LG to Samsung data transfer app, only requires one click to transfer everything you want. But there’s more to AnyDroid than that, let’s take a look at its main features.
So without wasting further time, let’s see how it works.
Step 1. Once you have download and install AnyDroid on your computer, connect both of your Android devices to your computer via USB cables.
Connect Your Phone to Computer
Step 2. Click on the Android Mover mode on the left-side panel > Select Android to Android > choose any types of data to transfer from Android to Android > click on the Next button to start the process.
Choose Android to Android
Step 3. Select the “Next” button and proceed. After selecting it, the transferring process of data from your LG to Samsung device will be started. Minutes later, you’ll see Transfer Completed page.
Android to Android Transfer Complete
There are so many ways to transfer data from LG to a Samsung device, and Samsung Smart Switch is one of them. Samsung specifically created the software to make it easier for everyone to transfer data from a source Android or iOS device to a new Samsung phone.
You don’t have to worry if you have no clue how to do it; simply follow the instructions below to understand the process.
Step 1. First, open Google Play Store on your LG and Samsung phone, and install the Samsung Smart Switch on both devices. Open the app, and on the source devices, select a sending device (LG) and a receiving device (Samsung).
Send Data Using Smart Switch
Step 2. Now choose the “Wireless” option as a method of transferring. Then connect your devices, and make sure that Bluetooth and Wifi are enabled on both devices.
Connect Your Phone to Smart Switch
Step 3. Once both phones are successfully connected, all you have to do is to choose the data you want to transfer. Simply press the “Send” button, allow the incoming data on your Samsung, and wait. You will be informed via the Smart Switch interface when the data transfer process is finished.
Choose Data You Want to Transfer
If this method does not work, you could try the next one.
If you have a Google account, transferring media files between LG and Samsung devices is pretty easy using Google Drive. Even though it is time-consuming, you can still try it for transferring all your data from LG to Samsung devices. You would receive 15 GB of storage on Google Drive. However, you can always purchase more storage depending on the requirement. Let’s get to the process.
Step 1. First, open the Google Drive app on both your LG and Samsung devices. Then, sign in with your Google account credentials.
Step 2. Open the app on your LG phone, and tap “+” then Upload. After the uploading is complete, select the files you want to transfer.
Transfer Media Files between LG and Samsung via Google Drive
Step 3. Once you have uploaded the files to your drive, open the app on your Samsung phone and open the google account. Now select the files you uploaded and download them on your Samsung phone.
If you think this method is difficult to follow, you can try the next one.
It is convenient to transfer contacts from LG to Samsung by using Gmail. Just like sharing files, you need a Gmail account. Similarly, you can transfer your contacts by syncing your Gmail account to your Samsung phone.
Step 1. On your LG phone, go to Settings, then Account and sync, click on Google, and then enable the Sync Contacts option.
Step 2. On your Samsung phone, open Settings, then Accounts and Sync, click on Account, select Add Account, then select Google and add the same Google account.
If you find this method tricky, you can try the next one.
When transferring data between two Android phones, Bluetooth has been the preferred method. Every Android phone has it by default, making it a widely known technology.
But keep in mind that Bluetooth doesn’t provide fast transfer speeds. So, if you wish to share a few files between your phones, adopt this option.
Let’s see how you can do it:
Step 1. Turn on Bluetooth on both of your phones first. You can do it by going to the Settings or Notification toggle. Then Pair your Samsung device.
Step 2. Choose the contacts, videos, or photos you wish to transfer from LG to Samsung phone. To continue, tap Share and then choose Bluetooth.
We hope that the above methods have helped you figure out how to effectively transfer data from your Samsung phone to your LG phone.
And from the above article, we reached at a conclusion that for recovering deleted photos on Android, nothing can beat AnyDroid at the first place. Not only is it fast, it can transfer the most types of data at once compared to other methods. Just download the free version to try.
