How to move music from SD card to phone? In this post, we have given one of the best ways to transfer music from SD card to Android phone internal memory.
SD cards and other external storage devices are a great way to expand storage space on the phone. They come with great storage capacity so that you can store as many files as you want.
Saving your important files and your favorite music on SD cards as a backup is a good way to protect them for data loss. However, for whatever reason you want to transfer music from SD card to phone, here we have mentioned an easy and quick way to do this.
To transfer music from SD card to phone, we recommended a powerful content management tool – AnyDroid.
It can help you to manage files present on inserted SD card on your phone in a more secure, convenient and efficient manner. The best thing about the software is that it lets you free yourself from digital cables, and allow you to connect your phone to the computer via Wi-Fi to manage content. Now, you don’t have to waste your time on managing your phone data.
Here are its key features:
To transfer your music files from SD card to phone, you can first download or transfer music files from SD card to computer. You can do this by connecting your SD card using a card reader to the computer, and download music files you want to transfer to phone on computer.
Once you are done with it, you can use AnyDroid to transfer download music from SD card on the computer to your Android phone. Here are the steps on how to do it:
Step 1: Download AnyDroid on your system. Next, install and launch it. After that, connect your phone to the computer using Wi-Fi or digital cable as per your choice.
How to Move Music from SD Card to Phone with AnyTrans for Android – Step 1
Step 2: Once the software detects your phone, you will see the interface as shown in the below figure.
How to Move Music from SD Card to Phone with AnyTrans for Android – Step 2
Step 3: Next, go to the Files management section, here you can click on “Add files/folders from computer to device” icon as shown in the below figure. Select the music files you downloaded from SD card on the computer to transfer them to your phone.
How to Move Music from SD Card to Phone with AnyTrans for Android – Step 3
Step 4: After that, the software imitates the transfer process. Within a few minutes, music will be moved from SD card to your phone.
How to Move Music from SD Card to Phone with AnyTrans for Android – Step 4
Whenever you want to move music from SD card to phone, AnyTrans for Android can help you do in an easy and quick way. We hope that the above guide helps you to move your music files from SD card to phone. It will be great if you share the guide with your friends too as they will also get to know about powerful Android data manager.
