5 Mi PC Suite Alternatives
Looking for some tools to transfer the data from one device to another? Here are some of the best data transfer tools we have mentioned in this post. Have a view!
Author Avatar Joy Taylor Last Updated: Apr. 20, 2022
People start facing problems with their smartphones while operating them and this is generally due to some storage issues. Many people didn’t get to know that storage of their phone is full. In such conditions, you need to transfer the data from your phone either to your PC or to any other device. If you are a Mi user and use Mi PC Suite, you can easily transfer the data with the ease of a few clicks. But if your mi pc suite not working and you are short of options then you must read this post till the end.
Here in this post, we have discussed below some of the best mi pc suite alternative that you can use to transfer the data. You can check all the details of them and pick one according to you.
Transferring data from your Mi phone to another device can be a huge task if your Mi PC Suite is not working. Here are some of the best mi pc suite alternative that can help you transfer the data from one Mi phone to another with the ease of one click.
AnyDroid
Transferring important files from your Android device to your computer ensures that your data is always protected if your device is updated, stolen, or destroyed. AnyDroid‘s one-click capability allows you to effortlessly transfer all Android contents to your PC. AnyDroid has some great features that make it the best mi pc suite alternative.
Pros
  • Handles all the media collection.
  • Transfers data quickly in just one click.
  • Transfers data from one device to another without any data loss.
  • Efficiently manage all your apps.
  • Compatible with Windows and Mac.
Cons
  • All the features are not provided in the free version of the app.
Now, Free Download AnyDroid to your computer firstly, then do the following steps.
Step 1. Connect your Android phone to computer via USB cables and then choose Device Manager.
Connect Android to Computer
Step 2. Pick the Data category.
Choose File Categories
Step 3. Then all data files on Android will be displayed > Select the items you want > Click To Computer to start transferring.
Data Transfer Completed
Dr. Fone
Dr. Fone is a superior mi pc suite alternative that can handle all of your smartphone data transfer needs. You may use it to transfer data between your Mi phone and your computer (Windows/Mac). You may also download and recover the data from your social media apps.
Mi PC Substitutes Dr Fone
Pros
  • It can easily transfer data from one device to another.
  • Provides a safe backup.
  • Manages the data on your phone like, contacts, documents, and others.
  • Updated according to the latest version of iOS and Android.
  • Works on both Windows and Mac.
Cons
  • The free version of the program does not have all of the functionality.
  • There isn’t a backup solution in one click.
MobileTrans
MobileTrans is a great way to transfer the data of your phone to the system or another device. It may, however, be used as a mi pc suite alternative for Mac/Windows due to its file transfer capabilities. It is an easy-to-use software and doesn’t take much time as well.
Mi PC Substitutes MobileTrans
Pros
  • Transfers data in just one click.
  • Transfers any kind of data like images, videos, SMS, etc.
  • Compatible with more than 6000 smartphone models.
  • Supports both Windows and Mac.
Cons
  • The program’s free edition does not have all of the features.
  • Only 7 days money-back guarantee.
Wondershare TunesGo
This TunesGo by Wondershare is another best mi pc suite alternative that will transfer your data from one device to another effortlessly and in no time. The software has a variety of tools that will assist you in transferring the data in some simple steps.
Mi PC Substitutes Wondershare TunesGo
Pros
  • It can directly transfer data from one phone to another.
  • Maintains the quality of data while transferring it.
  • Erases duplicate data while transferring.
  • Supports all Android phones.
  • Works on Windows and Mac.
Cons
  • You have to buy the whole suite to take advantage of all the features.
  • The free trial version has basic features but typically any of the advanced versions.
AirDroid
AirDroid is a user-friendly phone manager that you may use as mi pc suite alternative on your Mac, Windows, iphone, or any other Android phone to transfer the data. It’s a one-stop shop for storage, recovery, transferring of data.
MI PC Substitutes AirDroid
Pros
  • Transfers your data instantly.
  • You can operate your smartphone remotely.
  • Mirrors your phone on your laptop.
  • Compatible with iOS, Android, Mac, Windows, and Web.
Cons
  • The free version of the application is missing several functionalities.
  • For the free version, there is a data transfer restriction.
Here we have mentioned some of the feasible mi pc suite alternative that you can use to transfer the data from your Mi phone to PC. We will recommend you to use AnyDroid as it is the best mi pc suite alternative for transferring the data most easily and quickly. Moreover, it can also help you to free up Android storage, transfer data from iPhone to Android and so on.
