How to Fix iPhone Not Sending Texts to Android Phone
Is your iPhone not sending texts to Android? Read this guide as here we have covered some methods that can help you to fix this problem.
Author Avatar Joy Taylor Last Updated: Dec. 31, 2024
Undoubtedly, iPhone is a widely popular smartphone and users are always waiting when the new model will come on the market. However, it does not mean that iPhone is a perfect device as users also face various problems with it such as iMessage/Message problems on iPhone. For example, iPhone won’t send texts to non-iPhone, iPhone not alerting me of texts, iPhone won’t send pictures in iMessages, etc.
Several users have reported that they can’t send texts to users who are non-iOS users. It is a frustrating problem that iOS users ever face. Luckily, there is always a solution to every problem. Here, in this post, we come up with several methods that you can try to come out of this annoying problem.
Fixes to iPhone Not Sending Texts to Android Phone
The iPhone not being able to send texts to an Android device is a common problem and there can be many reasons behind this problem. However, whatever the reason is, below we have compiled some fixes that can probably resolve this problem with ease.
Fix 1: Check Device Settings
The first thing you can do to fix the problem is to check your device settings maybe you have changed some settings and you don’t remember at all.
Step 1: First of all, make sure that your device is connected to the cellular or Wi-Fi network.
Step 2: Now, open the settings and then, move to the “Messages” section. Here, make sure that MMS, SMS, or iMessage is enabled (Whatever message service you want).
Check Device Settings - Enable MMS, SMS or iMessage
Check Device Settings – Enable SMS & iMessage
Fix 2: Check Recipient Number
Maybe you have blocked the number on which you want to send the message. That’s why Android does not receive texts from iPhones.
Step 1: To begin the process, open the Settings on your iPhone and then, go to Messages.
Step 2: Next, go to Blocked, and here, check if the number is in the block list and if it is, then remove it.
Fix 3: Restart iPhone
It might be possible that there is a software issue on your iPhone that is putting a hindrance, So, the best thing you can do in this kind of situation is simply to restart your iPhone.
To restart iPhone X, 11, 12, 13,14:
Press and hold down the volume down or up and side button together until the power-off slider appears. Drag the slider to the right and wait 30 seconds to turn off your iPhone. And again, press and hold down the side button to turn it on.
To restart iPhone 6, 7, 8 and SE (2nd generation):
Press and hold down the side button until the power-off slider appears. Drag the slider and again, hold down the side button to turn it on.
Further Reading: iPhone Won’t Restart or Force Restart Not Working? >
Fix 4: Update iPhone Software
Have you updated your iPhone to the latest iOS? If not, then it can also be the reason why you are going through this annoying problem. So, check and update your iPhone software to fix the problem.
Step 1: Go to the settings app and then, open the General settings.
Step 2: Here, click on “Software update” and if an update is available, then download and install it.
Fix 5: Reset Network Settings
If your iPhone won’t send texts to non-iPhone, then another fix you can try is resetting your iPhone network settings. This will fix the problem if it is due to any network issue.
Step 1: Open the settings on your iPhone and then, go to the “General” section.
Step 2: Next, here, click on the “Reset” option and click on “Reset Network Settings”.
Fix 6: Deregister iMessage
Switched from iPhone to a non-iPhone device? You are not able to receive text messages from your iPhone maybe because the texts are sent as iMessage. This can occur if you have transferred your iPhone SIM Card to a non-iPhone device without turning off iMessage. Thus, in that case, all you can do is deregister iMessage. You can do it either on your iPhone or online:
Deregister iMessage On iPhone:
Step 1: Insert the SIM card you have transferred to an Android device from your previous iPhone into your iDevice.
Step 2: Ensure that you are connected to the cellular data network.
Step 3: Now, go to Settings and then, go to “Messages” and here, disable “iMessage”.
How to Fix iPhone Not Sending Texts to Android Phone via Deregister iMessage (iPhone)
Deregister iMessage Online:
You can go to the Deregister iMessage online website and here, you can remove your phone number from the iMessage service to fix out the problem you are facing.
Fix 7: Use AnyFix to fix iPhone System Problems
Many iPhone users have been experiencing messaging issues recently and receiving messages like “iPhone is not sending text messages to Android.” But don’t worry, AnyFIx is a powerful iOS system repair tool. He can quickly fix 150+ system issues for iOS including “iPhone not sending text messages to Android”.
Step 1. Download AnyFix and run it on your computer > connect your iPhone to the computer > choose the System Repair.
AnyFix System Repair Option
Step 2.  Follow the guide on the screen to select the corresponding question. Then click on Start Now button.
AnyFix System Repair App Issues
Select The corresponding question
Step 3: Select a mode to repair your device. AnyFix provides you three modes based on different situations. If you need to fix problems but don’t want to lose data, Standard Repair mode is recommended. And Standard Repair supports the most common system issues.
Choose Standard Repair Mode
Step 4. After clicking the standard repair button, you will see the below interface. Click on the Download button.
Step 5. As the firmware download completes, you will see the below page. Click the Start Standard Repair button.
Step 6: Then AnyFix will start to repair automatically. Wait a minute and it will show you the Repair Completed page as below. Check your camera then!
Repair Completed Page
Fix 8: Contact your Carrier
Still, if your iPhone not sending texts to Android, then it might be a major issue with the network. So, in this case, you should contact your carrier.
Therefore, this guide covers all the possible ways to fix the problem of iPhone not sending text messages to non-iPhone. So, try the above methods and hope it solves the problem for you. If you need a quick and hassle-free solution with a high success rate, look no further than AnyFix.
