How to Transfer Photos from Huawei to PC with 5 Ways
How to transfer photos from Huawei to PC? If so, then you’re in the right place as here we will help you learn how to transfer photos from your Huawei phone to computer in four different ways.
Author Avatar Joy Taylor Last Updated: Oct. 25, 2023
DroidKit – Android Photos Transfer
How to Transfer Photos from Huawei to computer? DroidKit makes it easy to transfer photos from Huawei to laptop/PC. No technical skills are required. Just download it to have a try!
Huawei is one of the world’s leading smartphone manufacturers. Lately, the brand launched new Android-based devices – Huawei P50, Huawei P50 Pro and Huawei P50 Pocket. The highlight feature of these smartphones is cutting-edge shooting. The cameras work to deliver a better quality of pictures.
Of course, when you bought a new one, you may capture a lot of pictures with a dual camera. Consequently, you may find yourself in the need to transfer these photos to computer for backup purposes. But, if you have no clue about transferring photos from Huawei to computer, then you have come to the right place. Continue reading to learn four ways to transfer photos from your Huawei smartphone to the computer with ease.
Also Read: How to Fix Huawei Phone Clone Not Working >
How to Transfer Photos from Huawei to PC without Hisuite
If you are not sure how to move photos from Huawei phone to PC with HiSuite that Huawei-designed application that can be used for backup and recovery, you just need a way to transfer photos from your Huawei phone to a PC. DroidKit – Android Data Manager can help you transfer all your photos or a part of photos from Huawei to PC. What’s more, you can manage your data on your Android phone, Including messages, photos, videos, contacts, calendars, etc. Look what DroidKit can do for you:
DroidKit – Android to PC Data Transfer
  • You can preview/select the photos you want to transfer as you need.
  • Manage & transfer Android Data and Files in no more than 3 steps.
  • Recover deleted photos from your Android device or SD card.
  • 100% Safe. All the data is encrypted throughout the process.
Step 1. Free download DroidKit and launch it on your computer (Windows/Mac) > Choose the Device Manager under Data Manager function and connect your Huawei phone to computer.
Step 2. Tap on the Export Content option > Tap on Photos.
Choose Export Content
Step 3. Now you can preview and choose the Photos that you want to transfer > Click on the To PC button.
Choose Data You Want to Transfer
Step 4. Just wait for a moment, when the transferring process is completed you will see the interface below.
Data Transferred Successfully
Transfer Photos from Huawei to PC via USB Cable
A traditional way of transferring data from an Android device to the computer using a USB cable may not be cool, but can help you get the job done without much hassle. So, follow the below steps to learn how to use the USB cable to transfer photos from Huawei phone to PC:
Step 1. Connect your Huawei phone to the computer with the help of a USB cable and the computer will detect it as a removable USB drive.
Step 2. Check the notification panel on your Huawei phone, and connect as “MTP/File Transfer”. Then, click on “Ok” when you get a message saying, “Allow USB Debugging”.
Check the Notification Panel on your Huawei Phone
Step 3. Make sure that your Huawei phone driver installed successfully on the computer. Then, go to “This PC/My Computer”, and access your device from the list of portable devices.
Step 4. Locate the DCIM folder, where all the pictures are saved.
Locate the DCIM Folder on Computer
Step 5. Select the desired photos, copy them and finally, paste the selected pictures on your computer.  Else, you can simply drag and drop the selected photos from your Huawei phone to your computer.
Sync Huawei Photos to PC via Huawei Data Manager
If you find the above methods complicated for Huawei to transfer files to PC, then no worries!! You can simply turn to AnyDroid, which is a one-click solution to transfer Huawei photos to PC. With the help of this Huawei data manager, you can sync not only photos but other common file types like videos, documents, etc from your Android device to PC directly. Unlike other methods, AnyDroid helps you get the job done in no time.
Now, download AnyDroid from its official website on your Windows PC and then follow the below steps:
Step 1. Run AnyDroid and connect your Huawei device to the computer with the help of a digital cable.
Connect Android Phone to Computer
Step 2. From the main interface of the software, click on the “Device Manager” button and choose “Photos” > Now, you can choose the photos you would like to transfer from your Huawei smartphone to your PC. Once selecting the desired data, click the “Next” button.
Choose the Photos you Want to Transfer
Step 3. Let the software complete the transfer process.
Transfer Huawei Photos to PC with Huawei HiSuite for Windows
If you have used Huawei device before, then you should probably know about Huawei HiSuite for Windows. It is a desktop app that you can use for the purpose of backup and recovery. With the assistance of it, you can backup content from your Huawei phone to your computer. If required, then you can even restore backed-up data.
So, get the Huawei HiSuite for Windows on your computer and then follow the below steps to learn how to transfer Huawei photos to PC using this desktop application:
Step 1. Connect your Huawei device to the computer with the help of a USB cable.
Step 2. Next, on your Huawei phone, go to “Settings”. Here, type “HDB” into the top search bar. From the search results, tap on “Allow HiSuite to use HDB”.
Allow HiSuite to Use HDB
Step 3. Once connected, agree to the privileges on your phone.
Step 4. Open Huawei HiSuite on your PC, and press “Backup”. Then, select the target file types you would like to back up, for example, photos, videos, etc.
Open Huawei HiSuite on PC and Select the Files to Backup
Step 5. After selected the files, choose a destination folder on your computer where you want to save the backup data, and then click on the “Save” button.
Transfer Huawei Photos to PC Using Huawei Share
An in-built functionality of Huawei smartphones, Huawei Share comes in handy to transfer data between two Huawei devices or a Huawei device and Windows PC/Mac.
As it transferred the data through a Wi-Fi connection and so, both the receiver and sender should be connected to the same internet connection. However, below is the step-by-step guide on how to use Huawei Share to transfer Huawei photos to the computer:
Step 1. On your Windows PC, go to “Control Panel”>” Programs and Feature”. Then, click on “Window features on or off” and ensure that “SMB1.0/CIFS File Sharing Support” is checked.
Go to Window Features and Check SMB1.0/CIFS File Sharing Support
Step 2. Turn on “Network Discovery” and “File Sharing” on your Windows PC.
Step 3. After then, go to “Settings” on your Huawei phone and click on Device connection.
Step 4. Now, you’ll here find the Huawei Share settings. Just, click on it and turn on the “Huawei Share” and “Computer share” option.
Go to Settings and Turn on Huawei Share and Computer Share
Step 5. Once enabled, you need to set up a username and password. And ensure that both your Huawei device and computer are connected to the same Wi-Fi connection.
Step 6. Click “My PC” on your computer and go to “Network” to select your Huawei device to access its data on the computer.
Access Huawei Data on the Computer
That’s how Huawei share to PC works and you’re ready to transfer photos from your phone to PC.
Hopefully, this guide has provided you with a suitable way to transfer photos from Huawei to PC. Considering everything discussed here, it is clear that DroidKit is the smart solution to get your job done. The software not only helps to transfer your content from Huawei to PC with just one simple click but does the job comparatively quite fast as compared to other methods.
