How to Transfer Photos from Huawei to Mac
How to transfer photos from Huawei to Mac? Read the guide below and learn six ways to transfer photos from your Huawei phone to your Mac without much hassle. And, you can fix Android not connecting to Mac.
Author Avatar Joy Taylor Last Updated: Apr. 12, 2022
You may want to transfer your precious memories in the form of photos, including HEIC photos on Android, to keep a backup on a computer. Usually, you can easily connect your Huawei Android to Windows PC and transfer data with a USB cable. However, how do I transfer photos from my Huawei phone to Apple, because of different operating systems?
No worries!! If you need to transfer from Huawei to Mac, or found that MacBook cannot detect your Android phone, this post will show you some proven ways to transfer photos from Huawei to Mac successfully.
Transfer Photos from Huawei to Mac with Android File Transfer
Android File Transfer is designed to help you transfer content from an Android device to Mac. This tool can transfer data such as photos, videos, and music. To help you get started with Android File Transfer, read the quick guide below to use it:
Step 1: To begin the process, get the Android File Transfer on your Mac.
Transfer Photos from Huawei to Mac via Android File Transfer- Step 1
Get Android File Transfer on Mac
Step 2: Connect your Huawei phone to the Mac with the help of a USB cable. And click Allow Access on your phone.
Step 3: Open Android File Transfer on your Mac. Then, navigate to the “DCIM” folder and open the ‘Camera’ subfolder.
transfer-photos-from-huawei-to-mac-file-transfer-2
Find Photos from Camera Folder
Step 4: Choose the photos that you would like to transfer. And then finally, drag the selected ones to the folder on your Mac.
Transfer Photos from Huawei to Mac via Android File Transfer- Step 4
Drag and Drop Photos from Huawei to Mac
How to Connect Huawei to MacBook and Transfer Photos
If your Android Files Transfer could not connect to the device, or your Mac doesn’t detect Huawei, you can utilize DroidKit to get your mac to recognize your Android phone easily. DriodKit is a complete Android solution that enables you to manage & transfer Android data or fix Android connecting problems. Besides, it can solve Android phones are locked by screen lock, FRP lock, etc.
Check how can DroidKit transfer photos from a Huawei phone to Apple:
Step 1. Get DroidKit downloaded on your Mac > Open it and choose Data Manager.
Choose Data Manager
Choose Data Manager
Step 2. Connect your phone to Mac with a USB cable > Select Photos to preview all photos on your phone.
Choose Export Content
Step 3. Select any photos and click the to computer button.
Transfer Photos to PC
Step 4. After you get the Transfer Complete page, click View Files and you can check transferred photos on your Mac.
Transfer Phone to PC Completed
Also, you can click Export Content and select photos, videos, and audio to automatically start transferring process directly.
Select Photos and Videos
Send Huawei Photos to Mac via Bluetooth
You can take advantage of Bluetooth functionality to transfer files from your Huawei phone to your Mac. Using this method, you can move photos, documents, videos, and contacts between an Android device and Mac. But, of course, this method is going to take some time.
To transfer photos from Huawei to Mac using Bluetooth:
Step 1: First, you need to enable Bluetooth on your Mac. To do so, go to “System Preferences” > Turn on Bluetooth.
Transfer Photos from Huawei to Mac via Bluetooth – Step 1
Turn on Bluetooth on Mac
Step 2: Also, turn on Bluetooth on your Huawei phone by swiping down the status bar from the home screen and clicking the “Bluetooth” option to turn it on.
Transfer Photos from Huawei to Mac via Bluetooth - Step 2
Turn on Bluetooth on Huawei
Step 3: In a while, you’ll be able to see your Huawei’s Bluetooth name on your Mac. Click on it and tap the “Pair” option, a code will display. Use this generated code on your Huawei phone to allow the pairing request permission.
Transfer Photos from Huawei to Mac via Bluetooth - Step 3
Pair your Huawei Phone and Mac
Step 4: Now, you’re ready for Bluetooth sharing. Go to “System Preferences” on your Mac and click “Sharing” > Bluetooth sharing” and select the local folder where you want to save the received files.
Transfer Photos from Huawei to Mac via Bluetooth - Step 4
Enable Bluetooth Sharing on Mac
Step 5: Choose the photos on your Huawei phone you want to send from the Gallery. Hit on the “Share” feature and select “Bluetooth”. Finally, select your Mac computer to get the photos transferred.
Transfer Photos from Huawei to Mac via Bluetooth - Step 5
Select Photos and Share with Mac
Backup Huawei Photos to Mac via Andriod File Transfer Alternative
Looking for an Andriod File Transfer or Huawei Hisuite alternative to transfer photos from Huawei to Mac? If so, then AnyDroid can help you get the job done with one simple click. It can not only backup your Huawei content to Mac with a USB cable, but also transfer files to a computer wirelessly. Therefore, if your Bluetooth is not stable, AnyDroid helps you.
It can help you backup your photos and other data such as videos, documents, music, messages, contacts, etc. And, it allows you to migrate data when you switch from an iPhone or an old Android phone to a new phone.
Get AnyDroid on your Mac and follow the below steps to transfer your Huawei photos to your Mac in just one click:
Step 1: Launch AnyDroid on your computer and connect your Huawei phone to the computer with the help of a digital cable. Or download AnyDroid on your phone to connect Huawei to Mac wirelessly.
Connect your Huawei Device to the Computer
Step 2: Once the software detects your device, click on the “Device Manager” button and choose “Photos”. Later, select the photos you would like to transfer and then hit on the “Next” button.
Choose the Photos you Want to Transfer
Step 3: In a while, the software will transfer data on your computer.
Transfer Completed
Transfer Completed
Transfer Photos from Huawei to Mac with Image Capture
When it comes to transferring photos from Huawei device to Mac, Image Capture comes in handy. Well, Image Capture is a built-in feature of Mac. It is efficient, and fast, and can provide you with photo thumbnails to preview. If you don’t import pictures into the album, then they will be shown on the sidebar and will also display up in your photo library soon. Here’s how to transfer photos from Huawei to Mac using Image Capture:
Step 1: Connect your Huawei device to Mac with the help of a USB cable. Then, open “Image Capture” from “Applications”>” Folder” on your Mac.
Step 2: Choose your Huawei device from the list of the device and then preview the image info. Now, suggest you select or create a location for Huawei photos.
Step 3: Click “Import/Import All” to move photos from your Huawei phone to your Mac (Use “Import” to transfer the specific photos).
Transfer Photos from Huawei to Mac via Image Capture
Further ReadingHow to Fix Image Capture Not Working >
Transfer Huawei Photos to Mac via Huawei HiSuite for Mac
Last but not the least method to transfer Huawei photos to Mac is by using Huawei HiSuite. It is known as the desktop manager app that can help you backup or manage your Huawei data. Moreover, it can help you update your device’s firmware. To learn how to use Huawei HiSuite for transferring photos from a Huawei phone to Mac, follow the below steps:
  1. To start the process, download and install the Huawei HiSuite for Mac on your computer.
  2. Then, connect your Huawei phone to the Mac using a USB cable and open Huawei HiSuite. On your Huawei phone, check the USB notification and then set it to “Transfer files/MTP mode”. Also, enable “USB debugging” when requested.
  3. Open the Huawei HiSuite on your Mac and tap on the “Back up” option. Select the file types you want to transfer to Mac and click on the “Back Up” button to get the files transferred.
  4. If you want to transfer specific photos, then go to “Pictures” in the HiSuite main interface and select the desired photos you want to transfer. Finally, click “Export” and that’s it.
Enter Device Code to Hisuite
As you can now see that it’s no big trouble to transfer photos from Huawei to Mac if you know the right ways to get the job done. Nevertheless, DroidKit is a wonderful Android solution to transfer your Huawei content to Mac, and vice versa. You can download it and take a preview of it.
