Want to transfer files from PC to Android, but have no available USB cable around? Don’t worry. This post will show you proven ways to transfer files from PC to Android without USB. Just read on to check them.
For Android users, the most common way to transfer files from a PC to an Android is to use a USB cable. But sometimes you may encounter some situations, such as having no available USB cable at hand, failing to install the USB driver on your PC, or even the USB port is broken.
Transfer Files from PC to Android without USB
Therefore, to avoid Android not connecting to a PC, here we are going to show you how to transfer files from a PC to Android without USB, also you can view another proven way to transfer files between phone and laptop using a USB cable. Applying to all Android models and the new Samsung Galaxy models.
The quickest way to transfer files from PC to Android is using WiFi, no need to connect with a cable. It lets you transfer files to/from your computer, phone, or tablet over a wireless connection, no USB cable needed. AnyDroid is just the exact tool that has that function. It is one of the best Android file transfer tools that have been trusted by millions of Android users to safely transfer data over Wi-Fi. And below are its outstanding features on Wi-Fi file transfer.
Now, Free Download AnyDroid on your PC first, and then check out the steps below to transfer files from PC to Android without USB. Please connect your Android phone and PC to the same Wi-Fi network.
Go to App Store to download and install AnyDroid on your computer. Or you can download it by clicking the button below.
Launch AnyDroid on both your phone and computer > Tap the Scan button on the top right corner of your phone, and then scan the QR code that appears on your computer.
Connect Android with Computer Wirelessly
Click on Add Content mode to select the files on your PC.
Choose Add Content from Computer
Select the photos you want to transfer to your phone and click on Open button to continue.
Open Photos from computer to Android
Check the items > Click on Next button to transfer photos from PC to Android wirelessly.
Transfer Files from PC to Android without USB via Wi-Fi
If you can’t transfer photos from Android to PC, and vice versa, DroidKit is also a great Android data transfer allowing you to transfer files between phone and PC with a cable. Why can DroidKit help you transfer data from Android to PC successfully?
The software is a complete Android solution that enables you to manage & transfer Android data and fix all Android system issues like can’t connect an Android phone to a PC. That is to say, even if your phone is not detected by the computer. It gets charged but cannot transfer data, DroidKit will also fix that.
Besides, DroidKit enables you to recover photos from a broken Samsung, get deleted photos back on Android, etc.
With your Android phone connected with Windows PC or Mac, you can transfer photos, contacts, videos, etc. from your phone to your computer, and, add your saved apps, games, latest music, movies, top-selling books, etc. from the computer to your phone. Only several steps are needed.
Get the latest version of DroidKit on PC/Mac. Launch the software and choose Data Manager.
Choose Data Manager
Connect your phone to the computer with a USB cable.
Connect Phone to Computer
Choose Export Content to PC and preview what data types you can transfer to PC > Select the data that you need to transfer.
Select Data and Continue
Wait for the transferring process and later you will get the Transfer Complete page as below.
Transfer Phone to PC Completed
You can click View Files to check the transferred files on your PC.
View Transferred Files on PC
Further Reading: How to Fix Android File Transfer Not Working >
One of the methods to transfer files from PC to Android is using cloud syncing. If you have third-party cloud services, like Dropbox, Google Drive, OneDrive, or other cloud services, then file transfer between your PC and Android is just a piece of cake.
With these cloud services, you can get to your files from your PC, phone, or tablet, and the changes you make from one device will automatically sync across all your devices. And here we will take Dropbox as an example. Now, let’s check how to transfer files from PC to Android with Dropbox.
Go to dropbox.com and sign in with your Dropbox account > Click on the “Upload Files” button at the top.
Click Upload Files
Click on “Choose File” button and then select the files you want to transfer to your phone > Click on Start upload button, and the files will be uploaded to Dropbox and synced to your Android device.
Add Files to Dropbox on Computer
Go to Dropbox app on your Android device and open it > Sign in with the same Dropbox account > View and download the files you just added from your PC.
If you’re without a USB cable, one of the alternatives to transfer files from PC to your Android is to use Bluetooth. Before starting, you need to check whether your PC is Bluetooth enabled or not.
From your Android, go to “Settings” > “Bluetooth” > Turn on Bluetooth.
From your PC, go to “Start” > “Settings” > “Devices” > “Bluetooth & other devices”.
Once your device is discovered just select the “Pair” button next to it, your phone and PC will show a passcode > Match the password > Tap “OK” on your Android and “Yes” on PC.
From your PC:
Select “Send or receive files via Bluetooth” from your PC > Choose “Send files” > Select your Android device > “Next” > “Finish” > “Browse” > Choose the files you want to send to your phone > “Open” > Tap “Next” to send it > Finish.
From your Android Phone:
Select “Send or receive files via Bluetooth” from your phone > Choose “Receive files” > Select the location to save the files to > Finish.
If your computer can not detect your phone while transferring data, here are some solutions:
Further Reading:
What is the fastest way to transfer files from PC to Android?
How do I transfer files from my phone to my laptop directly?
Transferring files from PC to Android without USB is not a difficult task, as you have so many alternatives like AnyDroid. You can go through the methods first, and then choose the one you prefer to complete the wireless transfer job. Besides, DroidKit can help you to out of the connection problem, transferring files between phone and PC successfully with cable. Not only that, DroidKit can also help you transfer data directly from Android to PC.
