There might be many possible problems when users connecting Android to PC via USB cable. Here in this post, we would like to introduce a more effective way for users to connect Android to PC via Wi-Fi. Please keep reading.
To better manage Android files, generally users would connect Android to PC to help, and the most common way is to connect with USB cable. However, there might be many problems when connecting via USB. For example, your computer might not be able to detect your Android phone after connecting with USB. Loose USB cable would also cause undetectable situation. In order to prevent from this situation, here we’d like to recommend a software to help you to connect Android to PC via Wi-Fi. If you are interested in it, please keep reading and check more details.
To connect Android to PC via Wi-Fi, we need help from a third-party software – AnyDroid. Here are the reasons why we choose AnyDroid.
Now please follow the step-by-step guide to see how to connect Android to PC via Wi-Fi with the help of AnyDroid.
Step 1. Download and install AnyDroid on your PC.
Step 2. Run AnyDroid, you would see the connection interface like this.
Step 3. Download and run AnyDroid app on your Android phone, scan the QR code on your computer.
In this Step please make sure that your Android phone and your PC are under the same Wi-Fi.
Step 4. When AnyDroid has detected your phone, then it is successfully connected to PC via Wi-Fi.
This is all about how to connect Android to PC via Wi-Fi with the help of AnyDroid. After you have connected your Android phone to PC with AnyDroid, you could start to manage your mobile phone files. Download AnyDroid now, and try to manage your Android phone wirelessly.
