5 Easy and Quick Ways to Backup Android Phone to Mac
Discover the ultimate guide to backup Android to Mac! Don’t risk losing your valuable data – read now and choose a way you like to backup Android phone to Mac!
Author Avatar Joy Taylor Last Updated: Aug. 13, 2024
Read in: Read This Article in
繁體中文
DroidKit – Backup Android to Mac
How do I sync my Android phone to my Mac? Free download DroidKit to backup Android phone to Mac in simple clicks. All data types are covered, like photos, messages, videos, contacts, etc. Support all Android devices, like Samsung, Motorola, and more.
Are you worried about losing all your important stuff on your Android phone? Do you want to back up everything on your Mac? Don’t worry! In this era of technology, every problem has a solution.
Every one of us carries a lot of important data on our phones and is concerned about it. However, some possibilities can be the cause of data loss. It can be losing our phone or accidentally breaking its screen or anything else. Therefore, it is crucial to have a backup. In this article, we will provide 5 ways to backup Android phone to Mac. Let’s get started!
Backup Android Phone to Mac in 1 Click
If you have no clue how to back up Android to Mac, then DroidKit – Android Phone Toolkit is here to help you! With this tool, you can easily back up all your data in just 1 click and 3 steps. Then, all the Android data, like photos, videos, contacts, etc. can all be backed up to your Mac or Windows computer. You will never worry about losing data. Plus, It would be the most effective and easiest solution that will work on any Android device, like Samsung, Huawei, Xiaomi, Redmi, Oppo, etc. You can learn more about what DroidKit can do for you in backing up Android data.
  • Backup all Android data – Photos, videos, WhatsApp data, music, contacts, text messages, etc. All data types can be backed up by this tool.
  • 1-click batch backup/selective backup – You can directly back up all Android data with 1 click. Or, you are also free to preview and select any content you need to backup.
  • High speed, high quality – It only takes 1 minute to back up thousands of data like photos. Most importantly, all the data will be backed up in its original quality. No quality loss.
  • 100% confidentiality and security – No need to worry about data security. DroidKit uses the most advanced security technology to ensure that only you can access your data.
Of course, DroidKit also allows you to transfer your data from the backup to Android if you need. And DroidKit is not only limited to data backup. It is an all-in-one tool for many Android problems, including data recovery, FRP bypass, system fixing and cleaning, screen unlocking, and many more.
Before starting, free download and install DroidKit on your Mac/PC. Then follow the instructions given below to backup Android phone to Mac.
Step 1. Launch the DroidKit and select Device Manager in Data Manager mode. Then connect your Android phone to the Mac via a USB cable and click Start.
Choose the Device Manager
Step 2. Once your device is detected, click the Export Content option.
Choose Export Content
Step 3. You can preview all the data and choose what to back up.
Choose Data You Want to Transfer
Step 4. The backup process of your selected files will be started. Once it is completed, you will see the interface given below.
Data Transferred Successfully
Backup Android on Mac with Android File Transfer
Backing up your Android phone to your Mac is a smart move to safeguard your valuable data. Another way to do this is by using the Android File Transfer application. This app is designed by Google to back up Android data to Mac. However, to use this method, you must connect your Android phone to your Mac with the original cable. Here are the instructions to backup Android to Mac with Android File Transfer:
Step 1. Download and install the Android File Transfer app on your Mac.
Step 2. Now move the Android File Transfer app to the Applications folder on your Mac.
Step 3. Connect your Android device to the Mac via an original USB cable.
Step 4. Open the Android File Transfer app on Mac.
Step 5. Select and then copy the files you wish to backup from your Android device, and paste them onto your Mac.
Select the Files
Select the Files
This is a simple and effective way to backup Android to Mac. But unfortunately, the developers of this app don’t do updates, so there are chances that you might face bugs. However, if you are unable to perform this method, you can try the next one.
Backup Android to Mac via Google Drive
Another convenient way to back up Android to Mac is by using Google Drive. It is a simple and straightforward method and can be done by anyone. You don’t need any cable to do it. You just need your Google account and an internet connection. Let’s see how you can use Google Drive to backup Android to Mac. Here is how to backup Android phone on Mac via Google Drive:
Step 1. If you don’t have a Google Drive app, download it from the playstore.
Step 2. Open the Google Drive app and sign in to your Google account. You can create one for free if you don’t have an account.
Step 3. Once signed in, tap the “+” icon to create a new folder for your backup. Name it Android Backup or whatever you want.
Click + Icon to Create a Folder
Step 4. Open the folder you just created and tap the “+” again, but this time choose the file type you want to backup by clicking the Upload button.
Upload the data
Upload the data
Step 5. Once the upload is completed, sign in to the same Google account on your Mac. Navigate to the Android Backup folder and download your files from there.
However, if you cannot back up your data on Google Drive, you can use any other method in this article.
Bonus tip: If you need to restore Google backups, you can read How to Restore Android Phone from Google Backup? >
Backup Android to Mac with Smart Switch
How do I backup my Samsung to my Mac? If you’re using a Samsung Android device, you can use a Samsung Smart Switch to back up your Samsung phone data. Smart Switch can create backups from both Android to iOS. It offers a seamless and efficient way to transfer and back up your files. Let’s explore how to back up Android phone to Macbook/Mac using Smart Switch. Here are the instructions to use Smart Switch for backup Android to Mac:
Step 1. Download and install Samsung Smart Switch on your Mac.
Step 2. Launch Smart Switch on your Mac and connect your Android phone to your Mac via a USB cable.
Step 3. On your Android phone, tap Allow for USB debugging and grant access to your device.
Step 4. In the Smart Switch window, click on the Backup tab. Then select the content you want to back up to Mac.
Click the Backup Tab
Step 5. Select the backup location on Mac and click Backup to start the process. It can take some time, depending on the size of the data.
Once the backup is completed, you will see a pop-up All done on your Android phone screen. This means your data is securely stored on your Mac. Samsung Smart Switch also helps you to restore the data between Android and iOS devices. You can try the next one if you don’t want to use this method.
Backup Android Phone to Mac Wirelessly
If you prefer a wireless solution to backup Android to Macbook/Mac, AirDroid is an excellent option. AirDroid allows you to transfer files, manage your device, and back up data wirelessly. Let’s explore how you can backup your Android phone to your Mac using AirDroid. Here are the instructions to backup Android phone to Mac with AirDroid:
Step 1. Download and install AirDroid on your Android phone from the Google Play Store.
Step 2. Launch the AirDroid app on your Android phone and sign in. Or, you can create a new account.
Step 3. On your Mac, use a web browser to visit the AirDroid website web.airdroid.com. Then sign in here.
Sign in with Your AirDroid Credentials
Step 4. On your Android device, click the menu icon in the AirDroid app and select Backup & Restore.
Step 5. Choose the data you want to backup, such as contacts, messages, photos, videos, and more. Click the Backup button to initiate the backup process.
Step 6. Once the backup is complete, the files will be stored in your AirDroid account. On your Mac, navigate to the Files section and download the backup files.
Good job! With AirDroid’s user-friendly interface and wireless capabilities, you can easily manage and back up your Android data without cables.
Remember, data loss can happen unexpectedly, and it’s better to be prepared. In this article, we’ve explored 5 easy and quick ways to backup Android to Mac, and you now have a range of reliable methods to keep your valuable data. One such powerful tool that simplifies the backup process is DroidKit. It can help you back up all the data in just 1 click. So, say goodbye to the hassle of visiting tech experts, as DroidKit will take charge of your Android issues. Just free download DroidKit to have a try now.
