How to Connect Android to Mac to Transfer Files?
Learn how to connect Android to Mac easily and quickly using the simple tweaks shared here in this post.
Author Avatar Joy Taylor Last Updated: Aug. 23, 2024
DroidKit – Connect Android to Mac and Transfer Data
DroidKit allows you to connect Android to Mac and transfer any data from your Android phones to the computer. It supports almost all models of Android phones & tablets. You can preview and transfer files like contacts, photos, videos, etc. to Mac in few simple clicks freely.
If you are a developer and trying to connect an Android device to a Mac to test an application. Or, do you have some crucial files you would like to move or transfer from your Android smartphone to your Mac OS? However, the Mac can not recognize your device. Any idea how to solve it?
Connecting Android to a PC can be easy with the same ecosystem. But we also figured out some methods to connect your Android to Mac on an Apple ecosystem. So you can make your Mac detect the phone, transfer files from Android to Mac, or control the phone on a Mac.
How to Connect Android to Mac Wirelessly
For those who do not want to install a program on their Mac OS, Bluetooth is the first way to connect Android to Mac wirelessly. You can successfully transfer data or files from your Android to your Mac by connecting Bluetooth. To do this, check out the bulleted stepwise guide below.
Step 1. Turn on Bluetooth on your Mac.
To enable Bluetooth on your Mac, select System Preferences > Bluetooth. Ensure that the Bluetooth is on, and if it isn’t, tap on the ‘Turn Bluetooth On’ tab. Once you do this, your device will become discoverable by nearby Bluetooth.
Step 2. Enable the Bluetooth feature on your Android device.
Click on Settings > Bluetooth. Once you’ve done this, your Android smartphone will immediately scan for nearby Bluetooth.
Step 3. Pair your Android phone and Mac.
Click on the ‘Pair’ icon to connect both devices.
Step 4. Select a File to Share.
Locate the file you wish to transfer on your Android smartphone, and then click on it. Select the ‘Share’ icon and then choose Bluetooth as your preferred mode of sharing.
Connect Android to Mac and Transfer Data via DroidKit
 DroidKit – Android Phone Toolkit is one of the best toolkits developed to help you and me connect Android smartphones to Mac. It’s an amazing program with incredible features that can’t be found elsewhere. Besides allowing you to connect Android to Mac, DroidKit also supports you to transfer data such as photos, videos, contacts, text messages, and other common data and files from Android to Mac or PC computer.
As an incredible toolkit with a well-designed user interface, DroidKit also lets you easily navigate your way around it. Thus, it doesn’t matter whether you are an amateur or professional in the tech industry before you can use the Android toolkit. Here, we’ll show you a list of features that DroidKit can offer you:
  • Compatible with both Mac and Windows. Supports all Android smartphones and tablets.
  • Preview and transfer data between Android and Mac/PC computers according to your needs.
  • Recover various kinds of Android data and files if you delete them unexpectedly.
  • Supports FRP bypass, extraction of data from broken devices, clearing of system junk, and many others.
Detailed Tutorial Guide to Connect Android to Mac and Transfer Data via DroidKit:
Step 1. Free download the latest version of DroidKit and launch it on your computer > Launch it and select Data Manager mode.
Choose the Device Manager
Step 2. Connect your Android phone to computer > Tap on the Export Content option. You can see all the types of data that you can save from your Android phone to your computer.
Choose Export Content
Step 3. Now you can preview and choose any data that you want to transfer to your computer.
Choose Data You Want to Transfer
Step 4. Just wait for a moment, when the transferring process is completed you will see the interface below.
Data Transferred Successfully
[Video Tutorial] How to Connect Android to Mac and Transfer Files
Connect Android to Mac with Android File Transfer
Android File Transfer allows you to transfer files from Android to computer. And, you can first connect Android to Mac:
  1. Insert the USB into Android and Mac.
  2. Unlock your phone screen and open the Android Notification Panel.
  3. Tap the USB option and choose “File transfer” under “Use USB for”.
  4. Now, you can follow the on-screen instructions to move files to Mac.
You May Need: Android File Transfer Could Not Connect to Device >
Connect Android to Mac via Cloud Service
The use of Cloud Services is another amazing way to connect Android to Mac to transfer or exchange files. It involves the use of cloud services like Dropbox, Google Drive, and more. This method is simple, fast, and reliable. However, it does have its restraints; the need for a stable internet connection. Here we will use the Dropbox cloud service to explain. Download and install any one of the cloud services and then follow the next step.
To use Cloud services to transfer or move files from your Android to Mac, follow the stepwise guide given below.
Add Files to Dropbox on Computer
  1. Launch Dropbox cloud service on your mobile device, and register an account if you don’t have one available.
  2. Now that you’ve successfully signed in to your Dropbox profile, the next thing to do is to select and import your desired file.
Why is Android Not Connecting to Mac?
Usually, when the Mac does not detect your phone, a USB device may not work properly, a Bluetooth connection failed, etc.
  • If your Mac can not recognize your Android, you should check USB and cable connections first. Try a different USB cable.
  • Make sure that both phone and Mac are turned on and within range of each other when you are connecting wirelessly.
  • Also, try to enable Developer Options and USB debugging: Go to Settings > About Phone > Tap Build number 7 times to display Developer Options. From there. It may help Mac recognize your phone.
How to Cast my Android Screen to my Mac
If you want to connect Android with Mac to cast screen or stream videos, you can try some screen mirroring apps like AnyMiro. It is an easy tool to help you cast an Android screen to a Mac. It supports connecting Android to Mac both via USB and wirelessly.
Mirror Android to Computer
More Related: How to Screen Mirroring Android to PC/Mac >
Ultimately, connecting Android to Mac to transfer data is easier than ever with the tutorial guide provided here in this post. We’ve outlined the best 3 ways to connect Android to Mac to transfer files. Select your preferred method, and then employ it in your next project. Mind you, we recommend that you use the method involving the DroidKit toolkit.
