A Samsung phone with a broken screen is always annoying. And trying to back up data from a broken screen phone to a PC at this point is much more overwhelming. Luckily, this post discusses five methods for backing up a Samsung Phone to a PC with a broken screen.
Can you transfer data from Samsung phone with broken screen? No matter your Samsung screen is broken or Samsung device is dead, you can download DroidKit for free to complete Samsung data recovery easily. You can get back all data types like photos, videos, text messages, etc. All Samsung phone and tablet models are supported.
How to Backup Samsung Phone to PC with Broken Screen
Data is essential for everyone. Thus, it is vital to take care of it. Proactive measures should be taken to ensure that data is backed up at all times. However, there are instances when access to your mobile is hampered. For example, the screen of your mobile phone gets broken.
Now, how will you back up your data? The article is formulated to answer the question. The instructions are specially designed for Samsung users. It will explain different ways to back up Samsung phone to a pc with a broken screen. By the end, you will be able to back up your data to your PC.
Further Reading: 4 Simple Ways to Backup Contacts on Samsung >
DroidKit – Complete Android Solution is a sophisticated tool for recovering lost Samsung data. When your Samsung phone has a dark screen, a dead phone, a malfunctioning touch screen, or is stuck on the Samsung logo, it can help. You can retrieve the data from the system-damaged Samsung smartphone.
DroidKit is a completely broken phone data recovery, including screen broken and system broken. And you can also use it to transfer data from broken Samsung to a new Samsung.
DroidKit Full Version
Free get DroidKit now to experience its comprehensive functions!
Now, please follow the instructions below to start to backup your data:
Step 1. Download and install the latest version of DroidKit on your computer > Click on Data Extractor.
Step 2. Here you can view what data types you can recover from your device. And we take backup pictures as an example here. Check Photos and tap on Start.
Select Photos and Start
Step 3. Put your device into recovery mode. Get a PDA code and enter it. Then, click Download Firmware.
Enter PDA Code
Step 4. After that, DroidKit will automatically start fixing your Android system. After completing the fixing process, you will see the interface below.
Crashed System Fixed Successfully
Step 5. Then, you can preview all the photos and other data > Select data you want to recover > Click To Device or To PC.
Select the Data to Recover from Crashed Phone
Wait a minute and you will see the completed page.
As we have explained earlier, backing up your Samsung device is the easiest way. All you have to do is to connect your phone to your computer and follow the instructions carefully.
Samsung phones come with external storage. One can put in an SD card and store additional data. SD cards come in multiple sizes. Initially, they provided very little space. In the current age, SD cards can provide extra space of up to 1 TeraBytes.
The feature works best if you use SD storage as your primary storage. In that case, all of your mobile data will be stored on an SD card. However, if your phone is still functional despite a shattered screen, you may transfer all your essential files to an SD card.
In the following segment, we will guide you on using an SD card to back up your Samsung Phone.
Step 1. Pop open the sim tray.
In most modern smartphones, the SD card lies in the sim tray. Open the SIM tray, and insert a pin into the hole next to the SIM tray. Retrieve the SD card.
Step 2. Insert the SD card into the reader
For that, use an external reader by inserting your SD card into the reader and connecting the reader to your laptop or computer.
Computer Reading SD Icon
Step 3. Copy the data into your PC.
Locate the Photos folder on the SD card and transfer it to your desktop.
In that way, you can easily copy all the data on your SD card to the internal storage of your PC or laptop. Furthermore, you can keep the data in your SD card until you repair your phone or buy a new one. In that way, you have two backups, one on your SD card and the other on your PC.
Google Photos will assist you whether your phone is damaged and you want to retrieve photographs from the Gallery app or you just need to transfer photos from your old phone to your new phone. Additionally, regarding gallery photographs, Google Photos is usually a good option. Follow the steps given below to back up your Samsung phone via Google Photos.
Note: You must first enable Back up & Sync on your previous phone.
Opening Google Photos on Your PC
The method is also very effective if you want to back up your photos on your PC. There is an added advantage of this method. Your photos are being backed up automatically. You don’t have to manually back up your data in case of a broken screen. You must access the same Google account you use on your Samsung phone to back your photos.
Find My Mobile is a unique Samsung service that allows you to locate a misplaced Samsung mobile device. Additionally, this capability enables remote access to your Samsung account. To reduce risk, you can secure your phone, back up your data to your computer, or wipe all of its data. However, you must remember your Samsung account’s login and password. Therefore, if you cannot access your broken Samsung phone, follow these procedures to back it up.
Step 1. Visit https://findmymobile.samsung.com/ on your computer.
Step 2. Click Sign in and enter your login credentials.
Step 3. From the menu that appears, select Back up.
Step 4. In the next box, choose all the data types you wish to back up.
Step 5. After choosing data, click Back up. The information will then be backed up on Samsung Cloud.
Step 6. Access the account through your PC and download all the data.
Find My Mobile will get the job done. It works the same way your Google account works. Samsung Cloud also backs up your data automatically if you allow it in the settings.
If your phone’s screen is broken, but the rest of the system is functional, you can still use it or generate a backup using a mouse. You should have a mouse and an OTG adapter for this. Using a mouse, these are the steps to backup a Samsung phone with a shattered screen to a computer:
Step 1. Connect the mouse to the OTG adapter, then connect the adaptor to the phone’s charging port. You may now use a mouse to operate your phone.
Connect the Mouse to The OTG Adapter
Step 2. Unlock and activate USB debugging on your phone.
Step 3. Connect your phone to the computer and transfer the info to your computer.
The method requires additional use of hardware. You can easily buy the device online or visit any nearby computer shop. If the rest of the methods are not to your liking, you can use this one to address your needs.
All in all, data protection is crucial. If you need to backup Samsung phone to PC with broken screen, you can use the above methods. These methods will be your savior during rainy days.
However, it is highly recommended to use DroidKit. It is designed to fulfill the needs of users. Moreover, DroidKit is simple and user-friendly. Anyone with little tech knowledge can navigate the applications to back up and later restore data. Now, free get DroidKit to get the job done quickly.
