How to Backup Samsung Notes Easily [Solved]
Struggling to back up notes on your Samsung phone? This post has a simple guide explaining how to back up Samsung notes quickly.
Author Avatar Joy Taylor Last Updated: Feb. 25, 2025
Data backup is one of the best ways to safeguard your files should the worst happen in the future. When you back up your data files, you can easily access them from wherever it’s stored with minimum stress.
Samsung did well by providing users with a cloud storage facility Smart Switch where you can backup documents and access them freely later. You can also use your Samsung Cloud Account or a third-party app like Google Drive to perform a similar operation.  So if you have Samsung notes you want to backup, you can use any of these options.
With that in mind, how do you back up Samsung notes? Well, in this article, we’ve curated a simple guide that describes how to back up Samsung notes.
Here are some Android backup tools for you: Top 6 Best Backup Apps for Android >
Backup Samsung Note to Samsung Cloud
Samsung Cloud is the external storage media designed by Samsung for you to manage and organize your media files [videos, notes, music, and more]. It’s one of the most versatile backups you can count on for seamless storage.
This storage facility is available to selected Android operating systems. Folks on Android 7.0 and later versions have access to Samsung Cloud. Here’s the guide to backup Samsung note to Samsung cloud:
Step 1. Via the Settings menu page, head to Cloud and Accounts and tap on it.
Head to Cloud and Accounts
Step 2. Next, select Samsung Cloud, and a prompt requesting that you sign in to your Samsung account will immediately pop up. Type your details correctly to proceed. If you do not have a Samsung account, Simply register one.
Step 3. On getting to the Samsung Cloud page, click on the three vertical dots at your screen’s top right corner. A drop-down menu with three options will appear. Select Settings to proceed. Now tap on Sync and auto backup settings.
Tap on Sync and Auto Backup Settings
Step 4. Next, slide the icon next to the app you want to back up to enable data syncing and backup. Ensure you enable the icon for Notes. Instead of using the slide icon, you can select Auto Backup, and your data files will be synced automatically on Samsung notes.
Backup Samsung Notes with Smart Switch
Smart Switch is great technology developed by Samsung. This tool is brilliant enough to help you migrate your data from one Samsung device to another without disrupting the quality. It can also serve as a backup tool to help you store vital files like notes from your Samsung device to your PC.
It’s a simple tool with an easy-to-manage interface. To backup Samsung notes using Smart Switch, follow the procedure below:
Step 1. Add Smart Switch to your Windows computer app list. To do that, kindly download from a reliable source.
Step 2. Launch Smart Switch and connect via a USB cable cord with your Samsung phone. A notification will immediately appear on your Samsung screen. Click Allow to grant Smart Switch access.
Step 3. Navigate to where you have Backup on the Smart Switch app and click on it. All the data available for backup on your device will immediately appear on the Smart Switch page. Choose the ones you would like to back up and click on OK.
Choose Data to Back up on Smart Switch
Step 4. Wait until the backup process is over, and click OK to complete your Samsung data backup.
Although Smart Switch is a powerful data transfer and backup tool, it isn’t without its flaws as there are too several requirements your phone must meet. For instance, your Samsung phone must run on Android 4.3 or later. You must meet this condition to back up vital data or information using Smart Switch.
If your Smart Switch not working, please read: Samsung Smart Switch Not Working – How to Fix >
Backup Samsung Notes with Data Manager
With data management software like DroidKit – Android Phone Toolkit, you can save yourself the stress of the aforementioned techniques. DroidKit is designed with smart AI tech that helps you organize your data and back them up for future reference, so you will never worry about losing important data anymore. Besides, the operation of this tool is not difficult, and all you need to do is only clicking on the buttons. Even a technical novice will understand how to use it. And you can also explore more about DroudKit features below.
  • Cover all data – DroidKit allows you to back up nearly all Android data, such as music, video, photos, note, App data, etc. to your PC.
  • Lightening speed to back up – The entire backup process only takes a few minutes, no matter how many files you have.
  • Partial or batch backup – You can freely preview and select the data to be backed up. Or you can 1-click batch back up all the contents on your device.
  • Guaranteed quality and safety – All files will be backed up with original quality and will never be disclosed to anyone but you.
Additionally, you can employ the services of DroidKid to extract data, clear memory space, recover data, bypass locked screens, and bypass FRP lock. And you can use it to upgrade or reinstall your Android operating system.
Now free download DroidKit and apply the stepwise guide below to backup Samsung notes using it:
Step 1. Launch DrdoiKit and connect your Samsung phone using a USB charging cable. Select Device Manager.
Choose the Device Manager
Step 2. 3 blocks will appear on the screen. And if you want to back up selectively, you need to click the data type under the blocks. If you want to batch backup, just click on Export Content. Here we take batch backup as an example.
Choose Export Content
Step 3. Tick the box next to the Samsung notes you want to back up, and click the Start button at the bottom of the page.
Choose Data You Want to Transfer
Step 4. DroidKit will immediately start transferring the notes to your PC. A page confirming that the transfer is complete will pop up when the transfer is over.
Data Transferred Successfully
Backup Samsung Notes to Google Drive
Google Drive is a simple tool designed by Google LLC that provides data backup and storage services on all internet-enabled devices, such as Android, iOS, Windows, and Mac. You can use it to back up your Samsung notes without stress. Launch the Samsung Notes app on your phone and follow the steps below:
Step 1. Select one or more Samsung notes to back up to Google Drive.
Select Samsung Notes to Back up
Step 2. Next, tap on the Share button at the bottom of your screen.
Step 3. A prompt showing the supported output formats to export the Samsung notes will appear. Choose one and move to the next step.
Step 4. Now, tap on Google Drive, and enter your Google account details if necessary.
Step 5. Lastly, hit the Save icon, and the Samsung notes will be added to Google Drive.
Google Drive does have its limitations, as it depends solely on an internet connection for you to back up your files. Additionally, there is a storage limit. However, you can expand the space by subscribing.
Backup Samsung Notes with Share Manually
With the share option on the Notes app page, you can easily export data files from your Samsung device to another preferred location, which could be Cloud storage or other media. You can lear how to backup Samsung notes with Share manually below:
Step 1. Launch the Samsung Notes app on your device.
Step 2. Press and hold down the notes to backup.
Step 3. After completing the step above, a couple of options will appear on your screen. Kindly select Save as a file.
Step 4. Next, choose an output format you wish to export the file. The output options include; TXT, Image, Microsoft, and PDF.
Step 5. Once done, choose your preferred storage media to export the file.
The share option lets you export Samsung notes without difficulty. However, there is a problem with it, as it does not allow you to move multiple files simultaneously.
Recover Samsung Notes without Backup in Clicks
Besides helping you to organize and manage your Samsung notes, DroidKit could also be used to recover them conveniently even if you don’t have a backup. This software can recover up to 13 data types, including photos, videos, notes, and more. You can preview these data first and then decide what to recover. It’s very easy to navigate and can be accessed from all computer systems, such as Mac and Windows. Check out the instructions below to recover Samsung notes without backup via DroidKit:
Step 1. Download and open the DroidKit software on your PC and connect the new phone to it using the corresponding USB cable. Select Deep Recovery from Device in Data Recovery mode.
Choose Deep Recovery from Device under Data Recovery
Step 2. Once the device is detected, a screen as below will appear on your screen. You can choose the data type you want to recover and then click on Start button.
Select the Data Type You Need to Recover
Step 3. This tool will check the root status of your device. If you haven’t rooted your device, just click on Root Now.
Tap on Root Now to Continue
Step 4. Now all the contents will be listed on the screen. Browse and select the Samsung notes you want to recover, and hit the To Device or To PC button.
Select Android Photos to Recover
Select Android Data to Recover
Step 5. DroidKit will immediately recover the Samsung notes for you. Wait until the recovery is over, then disconnect the phone from the PC.
Data Recovery Successfully
Backing up Samsung notes could be tedious for folks without this tutorial guide. But for you, it’s an easy task to execute. We did provide 6 free ways to back up Samsung notes. Kindly select and apply your preferred method. Mind you, the ultimate method from this guide is the one involving DroidKit. DroidKit is the all-in-one Android solution to help you back up and recover Android data easily and quickly. It’s fast, reliable, and efficient. Just free try DroidKit now.
