Do you need to secure your important data? Our guide offers multiple methods to backup Android phone to PCs. Choose a method that fits your needs and ensure your data’s safety today.
Free get DroidKit to easily to back up Android phone to PC. You can preview all data intuitively and manage them efficiently in your way. Whether you export data to your computer or import data to your phone, you can make it in no more than 3 steps.
Life can be unpredictable. So when it comes to the data on your Android phone, it’s always wise to back up Android phone to PC. You must have photos, contacts, and apps that you don’t want to lose. Backing up your phone’s data to your computer is no doubt a simple way to safeguard your data. But the question is, how to do it? If you’re not sure about it, then this guide is just for you!
In this article, we will walk you through the various methods that can back up your Android phone to your PC. Before we start those methods, let’s first see why backing up our Android phone is necessary.
Mobile phones are vulnerable to various issues. But if you back up your Android phone to your PC, then you are secure no matter what life throws your way. Now, what are these difficult situations we are talking about? Let’s see!
For those who are short on time, you need a specialized tool to back up your Android phone. And one reliable option is DroidKit – the #1 Complete Android Solution. It provides complete Android phone management. An important point here is that DroidKit separates all your Android files before the backup. You can then selectively back up your Android phone to a PC. Isn’t it useful?
DroidKit is an advanced Android file transfer app for both Windows & macOS, which allows you to view all your files on your phone and choose photos to import to a Mac or Windows PC. Besides, DroidKit is a complete Android solution that you can unlock a phone when forget a password, fix all system problems on a Samsung device, recover deleted photos and videos, etc.
DroidKit is the most versatile data transfer program with superb capabilities for ensuring flawless file conversion from Android to PC/Mac. DroidKit can transfer files up to 20 GB in size from Android to PC without sacrificing quality. This software provides the simplest approach to transport data and requires no technical knowledge to use.
Free get DroidKit>> and follow along to backup Android phone to PC:
Step 1. Free get and install DroidKit on your computer > Click on the Device Manager option under the Data Manager mode.
Choose the Device Manager
Step 2. Connect the Android phone to PC with an appropriate USB cable > Select Export Content, and choose any data category you’d like to transfer.
Choose Export Content
Step 3. Preview all of your contacts and select them > Click the To PC button.
Choose Data You Want to Transfer
Step 4. Wait for a while, you will get the Transfer Complete page. You can click View Files to check them on your computer.
Data Transferred Successfully
A Google Account is your ticket for using various Google services. These services include Gmail, Google Drive, Google Photos, and many others.
When it comes to backing up data from your Android phone to your PC, Google Drive and Google Photos come in handy. Moreover, most Android phones have built-in options to use these features of Google. You can automatically back up your contacts, messages, and other media files to Google’s cloud storage solutions. Then, you can access this data from your computer or any other device with your Google Account.
Backing up Android phone via Google Drive
Backing up Android phone via Google Photos
Turning Off the Google Photos backup option
Now, considering these limitations, let’s show you another method that is both free and unlimited.
Using a USB cable that comes with most Android smartphones can also back up Android phones. You can easily transfer any data from your phone to your PC.
This simple method is especially useful for transferring files like photos, videos, and documents. On top of that, this process is very quick because it uses the File Explorer on your computer.
Step 1. Connect your Android phone to your PC using a USB cable.
Step 2. Now, pull down the notification panel on your phone. Now tap on the “Charging This Device via USB” notification. It will open the USB preference settings.
Step 3. Now, in the USB preference settings, choose the “File Transfer” option.
Step 4. Now you can easily Back up your Android phone to a PC. Open the File Explorer on your PC, and you’ll see a folder with your mobile phone name. Open it.
Step 5. If you have an SD card on your mobile, select the folder you want to back up and open it. All the files on your phone storage will be in the “Internal Storage” folder.
Open the internal storage of your Android phone on the PC
Step 6. Now browse your phone storage and find the files you want to back up. Then copy & paste these files into your computer.
Still, this method is used by many people to back up Android phone to PCs. But if you don’t have a connecting cable with you, then you can just use Bluetooth. Let’s see how it’s done!
Bluetooth is a technology that allows you to connect different devices wirelessly. It can be a convenient way to transfer some data from your Android phone to a PC. Moreover, you can do it without any cables. This makes it helpful for quick, on-the-spot backups. It’s also useful when you may not have other methods available.
However, Bluetooth is more suited for smaller files because of the transfer speed limitations.
Enabling Bluetooth on Android phone
Enabling Bluetooth on a Windows computer
Android phone appeared on PC file explorer
Opening Internal Storage on the Android phone
Backing up files via Bluetooth
So choose this Bluetooth method wisely, considering your situation.
Now, before we end our guide, we’ve got a special bonus for Samsung users. It’s no other than the Samsung cloud. They can use this cloud feature to backup Android phone to PC.
Samsung Cloud is a storage service specifically designed for Samsung device users. It securely stores your photos, settings, and other essential data.
This service also makes it easy to transfer files to your PC or another Samsung device. If you use a Samsung phone, it can serve as an efficient & convenient way to back up your Android phone.
Search for “Accounts and Backups” in Settings
Backing up data via Samsung Cloud
Now, you won’t need to worry about losing your mobile data anymore. This article offers multiple ways to backup Android phone to PC. We’ve equipped you with all the knowledge you need. You can use it to protect your valuable data from loss, theft, or hardware issues.
Depending on your needs, you can choose cloud methods like Google Drive and Samsung Cloud. You can also go for direct methods like File Explorer and Bluetooth. But if you want an ultra-quick and effective method, then we highly recommend using DroidKit. It’s an all-in-one Android handling tool that simplifies the process of backing up an Android phone to a PC. It also has many other features that can serve/manage your Android phone in one stop. DroidKit is worth a shot!
