No doubt, factory reset is a great troubleshooting technique to fix an Android mobile phone. But you need to back up your crucial files to avoid sudden loss as factory reset often wipes all content and settings. If you are looking to back up your phone, kindly check and apply any of the 6 techniques to back up an Android phone to a PC before a factory reset shared in this post.
Hi, My Vivo Y21 Android phone has been misbehaving recently, and I’ve decided to reset it to factory mode. But I’m scared of losing the data on the device. My friends advised me to back up my files to a PC before the factory reset. I don’t know how that’s done. Please help if you do.
Whether your Android phone is not responding to touch or showing any other software-related issues, a factory reset should come in handy. However, this operation often leads to the deletion of all the data stored on the device, which is quite annoying.
In order to avoid data loss, it’s advisable to backup files before carrying out a factory reset on an Android phone. There are several ways to do that, but the best 5 tricks will be described in this post. Keep reading as we unveil how to back up your Android phone to a PC before a factory reset.
Before carrying out a factory reset on your Android device, it’s important to move all irreplaceable data files to a safe place so you don’t lose them. Here are some crucial data files you have to backup before a factory reset:
The easiest and quickest way to backup your Android files before a factory reset is via a professional Android data backup tool like DroidKit. This software is a complete Android backup solution suitable for taking care of over 13+ types of Android data, such as photos, call logs, contacts, messages, audio, and more.
DroidKit offers a flexible way to backup your Android data without compromising the quality, as it allows you to select and preview data before migrating them to a safe place where it’s stored. Alongside the data backup functionality, you can also use this software to restore backup files with minimal hassles.
Now please take the following steps to back up Android phone before factory reset.
Step 1. Launch the program once you’ve installed DroidKit on your computer > Choose the Data Manager mode.
Choose the Device Manager
Step 2. Connect your Android phone to the computer via a USB cable > Once DroidKit detects your Android phone, it will scan the data on your device and navigate to the following interface.
Choose Export Content
Step 3. Choose the Export Content mode and access the interface showing the specific data on your Android device. Now, you can preview and selectively backup Android phone to PC.
Transfer Photo to PC
Native backup feature has been in existence for a while but it’s less popular. However, recently it has started gaining traction amongst Android users because of the innovation it has undergone.
With this feature, you can easily backup your Android phone before carry out a factory reset on it. You don’t have to be tech-savvy to use this feature. Check out the stepwise guide below to backup your Android before factory reset using the Native feature:
Click Backup and reset
G Cloud Backup is an excellent Android backup app with an easy-to-manage interface to ease your operation. This app allows you to backup data such as contact, photos, messages, documents, call logs, videos, and more before resetting your Android phone to factory settings.
You can use this app for all Android brands including Samsung, LG, Lenovo, and more. G Cloud Backup moves all data files to a cloud storage. This app is absolutely free to download from Google Play Store.
Follow these instructions to backup Android data using the G Cloud Backup app:
Backup Android via G Cloud
Limitations
MTP also known as Media Transfer Protocol is an extension established to facilitate data transfer from one device to another via wired connection. It lets you access the internal storage of any device, including PC/Mac, mobile phones, and SD Cards.
You can use MTP to transfer a number of data files, such as photos, music, video, document, etc. Backing up data with MTP is pretty straightforward and cost free. Here’s how to backup Android data via MTP:
Change the USB Mode to File Transfer/MTP Mode
Limitations
Samsung Smart Switch is another credible data backup solution you can use to manage your data before carrying out a factory reset on your Android phone. With this technology, you can backup a plethora of Android data files such as messages, calendar, photos, contacts, to mention a few.
Besides data backup, Samsung Smart Switch is useful for migrating data from your old phone to a new one easily and quickly. Smart Switch works for all Android models and operating systems.
Use this simple guide to backup Android data using Samsung Smart Switch:
Choose Data to Back up on Smart Switch
Garner more knowledge about how to backup Android phone to PC before factory reset by reading through the queries and answers below:
Resetting is a great troubleshooting technique you can use to fix your Android phone. It comes in handy when you need to resolve issues like:
Issues such as frozen screen, slow operations, and more can complicate your Android phone. However, you can fix them by simply resetting your phone to factory mode. This way, all content and settings causing your phone to malfunction are automatically wiped.
Factory reset can also be used to clean up your device, thereby creating space for you to import new data.
Before resetting your Android phone to factory settings, it’s important that you back up all data (both content and settings) on it. However, in a situation where you forget to do so, you need professional data recovery software to bring back all missing data files that have ever existed on the phone.
There are many software developed for this purpose, but DroidKit is the most suitable one. This tool is loaded with unique features to ensure the successful recovery of lost or permanently deleted data. You can count on it to help you retrieve your missing Android data with maximum quality.
Backing up your Android data to a PC before a factory reset is a great way to keep your crucial files off your device to avoid sudden loss after wiping it. Choose any of the techniques introduced in the post above to do this.
The best technique is one with DroidKit. We recommend this option because of the quality results offered. DroidKit backs up and restores data excellently without compromising the content.
