How to Backup Android Phone and Restore to a New Phone? 3 Easy Ways
If you have switched to a new Android phone, the following guide shows how to do an Android restore from a backup you have created earlier. The post covers multiple ways to create and restore backups on your devices. Read on to learn more.
Author Avatar Joy Taylor Last Updated: Apr. 14, 2022
You will switch to a new phone due to different reasons such as phone system upgrades, phone system issues like black screen, etc., but you may think: How do I transfer everything to my new Android phone? Because, while you can transfer a single file with file assistance, it’s not that efficient when you have to transfer all the data. Therefore, most people in this situation consider restoring data from backups, but usually don’t know how to do it.
Make Android Backup and Restore to New Phone
Fortunately, Android devices and many Android data tools can help you back up your phone and restore data now. When you set up a new device, you can restore the backup of the old device to the new one. That way you will instantly have all the content of your old phone on your new phone. If you are confused as to how all of that works, the following guide should walk you through the procedure step by step.
Android Backup and Restore to New Phone with Google Account
One of the ways to do the task is to do an Android backup and restore on the new phone using your Google account. You need to know that your Google account is not just a tool for you to log in to various websites, it also provides you with a backup feature to help you store the backups of your device in the cloud.
But how to restore backup from google drive to phone? When you get a new Android device, you can tap on the restore option to restore your old phone’s backup on your new phone. Your new phone will then download the backup from Google and copy all of its contents to your new device. The following is how you go about doing it.
Step 1. The first thing you need to do is to create a backup of your old Android phone. Go to the menu and launch the Settings App on your device. Then, tap on the Google option and then the Backup option to view backup settings.
Tap on Backup Option
Step 2. On the backup screen, you will find an option saying Back up to Google Drive. Turn the toggle for the option to the ON position and the Google backups feature will be enabled on your device.
Turn on Back up to Google Drive
Step 3. Wait while your phone creates a full backup of your phone.
Step 4. Begin to set up your new phone and when it asks if you would like to restore a backup, choose yes and enter in your Google login details for it to fetch and restore the backup on your phone.
Soon as the backup is restored, you will find that all of your old device’s contents are now available on your new device. From settings to applications, everything should be available on your new phone.
Please keep in mind you are going to need a stable Internet connection in order to smoothly restore a backup on your device. The entire backup gets downloaded from the Internet which requires a good amount of bandwidth and stability for it to not fail.
Android Backup and Restore to New Phone with Android Solution
Since you cannot selectively restore backups with your Google account, when you have too much data, it usually takes a long time to complete the entire data restoration process. Moreover, if your network is not very good, it is very likely to cause your restoration to fail. Therefore, in order to ensure a higher success rate, we recommend you a professional Android data tool: DroidKit – Android Phone Tookit. Read on to learn more about its features.
  • Free preview and selection – Unlike the Google account, DroidKit allows you to browse your entire data and select what you need to backup and restore. So your phone storage will not be occupied by a lot of useless data.
  • Ultra-fast data transfer – No matter how many files you have, DroiKit can help you complete backup and restoration within minutes, saving your precious time greatly.
  • Includes all data – DroidKit supports all Android data types. As long as those files are on your Android phone, you can easily transfer them with DroidKit.
  • Super Compatibility – Already changed to the newest Android phone model? Don’t worry, DroidKit supports all Android devices with Android systems 5 to 12.
Download and install DroidKit now, then follow the steps below to make Android backup and restore to new phone!
Make Android Backup with DroidKit
Step 1. Back up your Android phone first. Launch DroidKit on your computer, and then select the Data Manager option on the main interface. Click the Start button and connect your Android phone to the computer with a USB cable.
Choose Data Manager
Choose Data Manager
Step 2. Select File Categories. After the connection, select Export Content. You can see the file categories, and choose the categories that you need.
Select Data You Want
Step 3. Choose the data you want to back up. Then you can preview all the files in these categories and select what you want. Tap on To PC to transfer them to your computer.
Transfer Photos to PC
Step 4. Export data. After tapping, DroidKit will start to export your data to the computer. Wait a few minutes. When Transfer Complete appears on the screen, your Android backup is successful.
Transfer Phone to PC Completed
Restore Android Backup to a New Phone
Step 1. Restore your Android data then. Keep your Android phone connected to your computer. Still stay in the Data Manager interface. Select Add Content in the middle.
Choose Add Content
Choose Add Content
Step 2. Preview and select data to restore. Then choose file categories. After your selection, all files belonging to these categories will pop up in front of you. You can browse and select the data you want as needed.
Transfer Data from Computer to Device
Step 3. Transfer data to a new Android phone. Click Start and DroidKit will start restoring the data you selected for you. The entire process will only take you a few minutes.
Transfer Data from Computer to Android Complete
Android Backup and Restore to New Phone with Data Manager
Besides DroidKit, AnyDroid – Android Data Manager is also a recommended Android data backup and restore tool. This software can clone a variety of files including text messages, contacts, videos, Apps and more. And with this tool, whether it is data backup or restore, you can complete it with just one click, making file transfer between devices and between the device and computer full of ease. Most importantly, you don’t need to worry about the safety of your data. Because AnyDroid uses the strongest encryption technology to ensure that your information is only accessible to you.
Download AnyDroid on your PC or Mac and here is how you do to make Android backup and restore to new phone.
Make Android Backup with AnyDroid
Step 1. Launch AnyDroid on your computer, and connect both of your Android phones to your computer using either WiFi or USB cables. Then click “Content to computer” button. Choose the file categories and click Next to back up.
Choose File Categories
Step 2. You can also selectively choose the files you want to back up. Click the certain category icon in the main interface, then select the files you want, and tap on “Send to computer” icon.
Transfer Data from Android to Android with AnyDroid
Instead of restoring the backup to your new iPhone. You can directly transfer files from one Android device to another by using AnyDroid.
Step 1. Click on the option that says Android Mover in the left sidebar. Still, connect your phone to computer through WiFi or a USB cable. Then, choose the option that says Android to Android in the right panel as that’s what allows you to clone your device.
Click Android to Android
Step 2. Checkmark all the types you want and then click on the Next button. It will start transferring chosen file types from your old device over to your new device. Just wait the process to finish.
Android to Android Transfer Complete
As you can easily see, this method lets you copy all the content from one device and paste on another without even requiring an active Internet connection. So that’s how you backup and restore from backup to an Android phone using the AnyDroid app.
If you have purchased a shiny new Android phone and are not sure how to get your old data on it, the above guide should teach you how to create a backup of your old device and restore it to the new one. But in order to ensure a high success rate, we recommend that you give priority to using DroidKit for data backup and recovery. Give a free try to this powerful Android data manager now!
self serviceself service
iMobie Self-Service
reduceclose
customer service
End conversation
