Here is a list of top iPhone data recovery software we choose with advantages and disadvantages. You can choose the best one to get your lost data back to the iPhone.
All of a sudden My iPhone reset itself, and I lost all my data on it! Wanna use a program to get my photos and my text messages back? But so many iPhone data recovery softwares, how can I choose a capable one?
According to the investigation, you may have lost essential data due to an iOS update, accidental deletion, jailbreak failure, iPhone lost/stolen, etc. Usually, you can restore iPhone from backup. However, what if there is no backup, how do recover lost iPhone data? It’s necessary to get an iPhone data recovery software, which gives you the solution to recover data from iPhone without backup, even transfer data from an iPhone that is dead.
Top Causes of iPhone Data Loss
Everyone has their own standards on what’s the best iPhone data recovery software, for example: Can it recover my iPhone data without backup? How much does it cost for iPhone data recovery? After a long-term test and collecting customers’ views, we summarized the standards, did a comparison chart of the most popular apps, and finally picked out this top list. Keep reading and get the best iPhone data recovery software to recover data from your iPhone.
YES. First, you can restore iPhone from backup directly. Also, iPhone data recovery software helps you to recover lost iPhone data even without backup, or iPhone that won’t turn on.
Because when you delete iPhone files, which will not be permanently lost. And, data recovery software will deeply scan your internal memory and get it back until it’s overwritten by new data. Therefore, after iPhone data are deleted, you need to stop using your iPhone and get the data recovery tools below to recover from your iPhone directly.
According to the test result, PhoneRescue for iOS is the most comprehensive and powerful iOS data recovery tool among all those programs. It can help recover data from a broken iPhone, mistaken deletion, factory reset, software update failure, etc. By uplifting technical to a new standard, now the new version is able to retrieve up to 31 file types, which is far more than the most tool in the market. Till now, this app has already helped millions of users around the world.
PhoneRescue for iOS
Here are the simple steps to recover deleted data without backup (we take photos as an example):
1. Get the latest version of PhoneRescue for iOS Now, Click Recover from iOS devices from the home page.
2. Choose the Photos type to scan, or you can select all iPhone data to scan and check.
Scan All the Photos on iPhone
3. PhoneRescue for iOS will show you all the photos on your iPhone, and you can see the deleted icon on the deleted pictures. Select what you want, recover them To iPhone or To PC.
Recover Deleted Photos without Backup to Computer or iPhone
Also Read: How to Recover Deleted Apps on iPhone >
Dr.Fone – Data Recovery is one of the functions of Dr. Fone It is great for recovering deleted content from the iPhone. You can download Dr. Fone, then download and buy Data Recovery. Or you can download and buy Data recovery directly. And it can recover 7 data types from the device, and recover 7 data types from iTunes or iCloud backup.
Primo iPhone Data Recovery is made to orchestrate your files disaster retrieval plan with a super easy process. This tool gives great support to recovering up to 25 types of content: SMS/iMessage, Notes, Contacts, Call History, Photos, Reminders, etc. It also provides three recovery modes so no matter you have a backup or not you can get back deleted iOS favorites as you need.
PrimoSync iPhone Data Recovery Review
ApowerRescue is a good application if data loss issues happen with your iPhone. This app enables you to retrieve information from your backup file. You can choose any type of information you want to take back: photos, songs, contacts, messages, reminders and notes, and so on. But it might not be perfect as various problems you might encounter along the way. One problem is that it can’t access iCloud data.
ApowerRescue Review
Gihosoft is a powerful and user-friendly software that can help you retrieve up to 12+ types of content, including contacts, SMS, photos, etc. It ensures you recover your lost data due to iOS upgrade/jailbreak, accidental deletion, or device lost or broken. The easy-to-use interface is also designed to guide its computer users to correctly find the desired features.
Gihosoft iPhone Data Recovery
AppGeeker – iOS Data Recovery is another tool that allows you to get deleted important files back on your iPhone from those top causes of data loss. You can recover from iPhone directly, or iTunes/iCloud backup. Besides, it is a tool that can help you to backup & restore data on your iPhone, and avoid data loss again.
iOS Data Recovery from AppGeeker
If you have accidentally lost or deleted an important document from your iOS device, Enigma Recovery is another software that can help you take control of your data. With it, you can preview existing content on your device, iTunes, or iCloud backup. This is quite useful if you have lost your device and need access to the data on your backup file.
Enigma Recovery Review
For a clear comparison, we installed the latest version of these iOS restoration tools and tested them to recover deleted SMS, contacts, photos, and videos from an iPhone 8 plus this April. And below are the first 5 programs detailed review information.
PhoneRescue | Dr.Fone | Enigma Recovery | Primo Recovery | ApowerRescue | |
Recover from iDevice | ![]() |
Recover from iTunes | ![]() |
Recover from iCloud | ![]() |
Selectively Scanning | ![]() |
Time Consuming | 40 seconds | 2 minutes | 40 seconds | 2 minutes | 6 minutes |
Attachments Recovery | ![]() |
Data Comparison | ![]() |
Recover back to iPhone | ![]() |
iOS System Repair | ![]() |
Price | $49.99 (1 year) | $59.95 (PC) $69.95 (Mac) | $49.99 (single) | $39.99 (single) | $69.9 (1 year) |
Availability | Free Trial | Free Trial | Free Trial | Free Trial | Free Trial |
Files getting back process is a process of salvaging inaccessible contents from corrupted, damaged, or lost iPhone devices. Normally people can get reliable data recovery services from an expert or an app. But most people would like to try an easy-to-use program before seeking help from the expensive retrieval service nearby.
It usually provides you with three modes to retrieve what you’ve lost, including recovering from your device, from iTunes backup, and from iCloud backup. The recovery can be processed even if your mobile phone is lost, as long as the iTunes or iCloud backup has been taken in place prior to the inaccessibility of the device. Besides, some high-quality recovery programs are capable of repairing common system issues.
There are many specific categories of iPhone retrieval software such as photo recovery software, iMessage recovering apps, contact restoration apps, etc.
Our principles of defining what is the TOP data saver app are as same as how you’d like to recover the items in your lost handset. Before starting, you’d better clearly understand WHERE have you lost the content from? HOW did you lose them? WHAT types would you like to recover?
For the first question: WHERE have you lost your iOS content, from an old iPhone 5s/6/7/8/X/11/12, or a new 13? As Apple mobile product line covers over 10+ models, the first criterion we have chosen is compatibility. One good program should be capable of supporting all existing mobile device models and popular iOS versions like version 14/15.
For the second question: HOW did you lose your items in your cellphone, mistaken deletion? The device is lost or badly damaged? Do iOS get stuck? Studies show hardware/software failure and human error are the two most common causes of your content loss, but a different type of information disaster requires corresponding methods.
Therefore, the second criterion is methods. The top program should have methods to recover in various situations. And most apps have adopted cellphone file recovery approaches like recovering from the device, from iTunes backup, and from iCloud backup. And some apps can fix any issues or get back these lost documents from broken or water-damaged.
No matter how hard you’ve tried to recover your lost iPhone items, you still have the chance that you’ll lose them forever. So the third question, WHAT types of phone content would you like to recover? Actually, this is the most crucial standard to justify if your items’ restoration tool is qualified. All candidates listed below support a wild range of data recovery file types.
Usually, data recovery tools are priced with a 1-year license, and you can check every price plan on its store page and our review table.
We’ll collect some frequently asked questions about this topic online, as well as share some ideas on these questions.
We’ve reviewed all these apps, and found all of them offer free trial versions for limited use. And when users are going to recover lost data, they will charge a fee. So there is no free app in fact.
There are some cracked versions for these apps we’ve found. But it may be not secure and safe. The virus and malicious programs may be injected into these cracked files and do harm to your device, and even steal your private information.
Yes, most of the recovery apps are able to recover lost content without using any backup. They will scan the device to find those items that were lost but still stored on your device. Therefore, you may get back your lost items even no backup available.
Some users would like to use the iOS-based app to recover those lost items from the iPhone. But as we tested, most of these apps won’t get back deleted parts, and most of them require you to use their desktop app to do the work.
That’s all for the top 7 iPhone data recovery software reviews. We’re trying to figure out how can iPhone data be recovered, with or without backup, even from a disabled or dead iPhone. Also, it includes the questions that you may concern about. Hope those can help you recover lost iPhone data easily. And, PhoneRescue for iOS is the top 1 data recovery tool that provides you to recover lost iOS data, repair the iOS system, remove iOS passwords. Read the pros & cons above, you can download it and have a try.
As the frequency of iOS item loss is increasing, it’s suggested to consider taking proper precautions to decrease the cost and impact of item loss. A regular iPhone backup plan with a computer, or by iTunes and iCloud is always welcome.
