Are you tired of being bound by a single carrier and want to know how to unlock iPhone 13 carrier? This article details the legal steps to unlock iPhone 13 carrier lock. By unlocking iPhone 13, you can switch to a network service provider that suits you better and enjoy better coverage and offers.
Download AnyUnlock for free — Use advanced algorithms to quickly unlock iPhone 13 carriers
iOS unlocking tool trusted by users around the world
According to a 2023 report from the Cellular Telecommunications Industry Association, more than 40% of iPhone users want the flexibility to choose their network provider, citing reasons such as better coverage, cost savings, and access to exclusive offers. If you are frustrated with being tied to one carrier and want to unlock your iPhone 13 carrier, you are not alone. This article will provide you with several methods to help you successfully unlock your iPhone 13 carrier.
To check if your iPhone is carrier locked, you can check it in the following ways.
1. Click the “General” option.
2. Select “About this device”.
3. Scroll to the bottom and check if there is a “Carrier Lock” option.
1. Dial *#06# to get the IMEI number.
2. Enter the IMEI number on a professional website to check the lock status.
The SIM unlock chip is not only applicable to iPhone 13/13 Pro (Max), but may also be applicable to other models. Although official unlocking is still the safest and recommended way, for those who cannot wait or do not meet the conditions for official unlocking, the SIM unlock chip provides an alternative. Next, we will explore in detail how to use the SIM unlock chip to unlock the iPhone 13 series.
How to Unlock iPhone 13/13 Pro (Max) via SIM Unlock Chip:
1. Purchase a SIM unlock chip: Choose a SIM unlock chip for iPhone 13/13 Pro (Max) and ensure its compatibility and reliability.
2. Prepare the SIM unlock chip: Install the SIM card of the carrier you want to use on the SIM unlock chip according to the included instructions.
3. Insert the SIM unlock chip: Insert the unlock chip with the installed SIM card into the SIM card tray of the iPhone and make sure it is firmly installed.
4. Restart iPhone: Restart your iPhone to let it recognize the new SIM card and unlock chip.
5. Complete the activation steps: After restarting, according to the instructions provided by the SIM unlock chip, you may need to enter the unlock code included with the chip or follow the on-screen instructions.
6. Complete activation: After activation is complete, your iPhone should be able to recognize the SIM card of the new carrier and connect to its network. You may need to wait for a while until the iPhone completes the setup process.
If you are unable to bypass your iPhone 13 carrier using the SIM unlock chip, you can contact the service provider directly.
Here are the contact numbers for major US carriers:
Unlocking the carrier lock of iPhone 13 may bring restrictions and inconvenience to users, especially when they need to change SIM cards or use international roaming services. AnyUnlock is a professional iOS unlocking tool that uses advanced technology and multiple iterative updates to provide users with efficient and secure unlocking solutions. Supports unlocking screen passwords, bypassing MDM locks, unlocking Apple ID, etc.
Main features of AnyUnlock:
Step 1. Free download AnyUnlock on your Windows PC or Mac. Click on Remove SIM Lock on the home page.
Choose Remove SIM Lock
Step 2. Connect your iPhone to the computer and make sure your iPhone is jailbroken before clicking Remove Now to continue.
If your iDevice isn’t jailbroken, follow the on-screen instructions to jailbreak your iPhone on your own.
Click Remove Now
Step 3. Follow the on-screen instructions to Forget This Network on your iPhone.
Forgot This Network on iPhone
Step 4. AnyUnlock will start removing SIM lock as below.
Start Removing
Step 5. Once the SIM lock is unlocked, you will get the success page.
SIM Lock Removed Successfully
AnyUnlock is undoubtedly the best choice for unlocking iPhone 13 carriers. This powerful tool is not only easy to operate and efficient, but also ensures data security around the world. Compared with other unlocking methods, AnyUnlock provides users with a one-stop solution.
But AnyUnlock’s functions go far beyond that. It can also help you remove Apple ID, bypass screen lock, and even remove MDM restrictions. Whether you want to switch carriers freely, use a local SIM card when traveling abroad, or need to solve the problem of second-hand device lock, AnyUnlock can meet your needs.
1. Can I jailbreak my iPhone to unlock carrier?
No, jailbreaking an iPhone does not unlock the carrier.
2. Is jailbreaking the same as unlocking?
No, jailbreaking and unlocking are not the same. Jailbreaking allows users to gain root access to the iOS file system, while unlocking removes carrier restrictions.
3. Can I sell my carrier locked iPhone?
Yes, you can sell a carrier-locked iPhone, but you must disclose its locked status to the buyer.
In summary, unlocking the carrier restrictions of iPhone 13 does not require complicated operations or professional knowledge. Through the detailed introduction of this article, you have learned many ways to unlock iPhone 13 Carrier, and the most recommended one is to use AnyUnlock, a powerful and convenient tool. AnyUnlock can not only quickly and safely remove carrier restrictions, but also has many practical functions such as removing Apple ID, screen lock and MDM restrictions.
