Discover effective methods to bypass iCloud on iPad Mini 2/3 in this comprehensive guide. Explore options like DNS bypass, contacting the previous owner, jailbreaking, and leveraging tools like AnyUnlock for efficient iCloud removal. Unlock your device hassle-free and regain access quickly with these proven techniques.
Whether you’ve encountered an iCloud lock after purchasing a second-hand device, or you’ve forgotten your Apple ID credentials, finding an effective solution is crucial. If you want to learn how to bypass iCloud on iPad Mini 2/3, you’ve come to the right place! This article explores six proven strategies – from DNS bypasses and contacting the owner directly to advanced tools like jailbreaking and AnyUnlock – that enable users to quickly and securely unlock their iPad Mini 2/3 devices.
1. Click “Unlock with Password” under the Apple ID Password column:
On the iPad Mini 2’s Activation Lock interface, you will see an option to use the device’s screen password to unlock. Find and click “Unlock with Password”.
2. Select Use Device Password and enter your screen password:
You will be prompted to enter the device’s screen password. Enter the screen password you normally use to unlock your iPad.
3. If it fails, enter the password again until you successfully unlock the Activation Lock:
Sometimes the first time you enter the password, it may not be successful. At this point, you can try a few more times until you successfully unlock the Activation Lock.
bypass activation lock on ipad mini using screen passcode
NOTE:
The device must be associated with an Apple ID: This method usually only works if you have logged in with your Apple ID on the device and enabled “Find My iPad”.
Keep the device online: Your device needs to be connected to the Internet in order to verify your Apple ID and password.
Reset frequency limit: If multiple attempts are still unsuccessful, the security mechanism may be triggered, causing you to wait for a while before you can try again.
If the above method does not unlock the iCloud activation lock of your iPad Mini 2, you can also use a reliable third-party tool to unlock it.
AnyUnlock is a professional iCloud activation lock removal tool that uses advanced unlocking technology to help users easily bypass activation lock. Whether it is because you forgot your Apple ID password or the device you bought from someone else is locked, you can easily bypass iCloud activation lock without Apple ID or Apple ID password.
Key Features:
Step 1. Free get AnyUnlock – iPhone Password Unlocker installed. Launch the software and you will see the page below and tap on Bypass iCloud Activation Lock.
Step 2. Connect your device and click Start Now button.
Connect Your iOS Device to the Computer
Step 3. Then, you need to jailbreak your device to allow AnyUnlock to bypass. Read the jailbreak tutorial to do and click Next once finished.
Jailbreak Your Device
Step 4. Then you can start bypassing after clicking Start Now button.
Bypassing iCloud Activation Lock
Step 5. Wait until the process is finished, and you will get iCloud Activation Lock is bypassed successfully page as below.
iCloud Activation Lock Is Bypassed Successfully
Apart from this, there is another way to bypass Activation Lock on iPad Mini 2 without Apple ID password. This method is more complicated and is recommended for users with a technical background.
1. Start your iPad:
2. Connect to Wi-Fi:
3. Join your Wi-Fi network:
4. Access apps and features:
From here, you can access various apps and features, such as YouTube, Mail, Maps, and more.
If you remember your Apple ID password, you can bypass icloud easily. If you don’t remember, it doesn’t matter. The following section will show you how to retrieve your Apple ID password and then bypass iCloud on iPad mini 2.
1. Unlock Apple ID
First, you need to reset your Apple ID password by visiting your Apple ID account page, tapping “Forgot Apple ID or password?”, and following the instructions. Once you’ve confirmed that your password has been successfully reset, return to the device you need to unlock.
2. Unlock iCloud Activation Lock with Apple ID Password
The device will restart and display the initial setup screen. Follow the on-screen instructions to complete the setup. Then you have successfully bypassed iCloud Activation Lock.
If you are unable to unlock your device using your Apple ID password, you may need to contact Apple Support for help. You will need to provide your device’s serial number and proof of purchase.
Or
You can try to use some third-party tools to bypass iCloud activation lock. In the above article, we have introduced how to quickly bypass iPad Mini 2 iCloud activation lock through third-party tools – without Apple ID password. This is a proven and trustworthy professional IOS unlocking tool.
This method is particularly useful if you purchased a used device that is still associated with the previous owner’s Apple ID. In this section, we’ll outline how contacting the previous owner can help you remove the iCloud activation lock.
1. Find the previous owner:
If you purchased a second-hand iPad, try contacting the previous owner and asking them to delete the device from their iCloud account.
2. Delete from iCloud:
3. Restart iPad:
Restart iPad and the activation lock will be removed.
1. Download the jailbreak tool:
2. Connect your iPad:
3. Jailbreak your device:
1. What is iPad iCloud Activation Lock?
iPad iCloud Activation Lock is a security feature designed by Apple to protect the security of your device and data. If your device is marked as lost or stolen, Activation Lock prevents others from using your device without the correct Apple ID and password.
2. Why do I need to bypass iPad iCloud Activation Lock
3. Can I manually bypass iCloud activation lock?
Manually bypassing iCloud activation lock is very difficult because Apple has designed a very strict security mechanism. Most users need to rely on professional tools like AnyUnlock to ensure that they can successfully unlock the device without affecting normal use.
In this article, we have discussed several common methods to bypass iPad Mini 2 and iPad Mini 3 iCloud activation lock in detail:
In summary, although each method has its own unique advantages and applicable scenarios, if you are looking for a fast, safe, and technically-free way to bypass iPad Mini 2/3 iCloud activation lock, you can try AnyUnlock. It not only effectively solves the problem, but also ensures the safety of your device data and normal use experience. Download AnyUnlock now and easily remove iCloud activation lock!
