How To See Notification History On iPhone 2024!
Have you ever missed an important notification on your iPhone and wanted to go back to it? With our simple guide, you’ll learn how to easily access notification history on your iPhone. No more missed messages or ignored alerts.
Author Avatar Joy Taylor Last Updated: May. 14, 2024
Have you ever missed an important notification on your iPhone and wanted to go back to it later? Luckily, Apple offers a feature that allows you to view your notification history, ensuring you never miss an important update again. In this article, we’ll guide you through the steps to access and manage notification history on your iPhone.
How to View Notification History on iPhone?
We all have the experience of missing important notifications on our iPhone. Luckily, Apple provides a feature that allows users to view notification history. Here are the steps to view notification history on iPhone.
Enable notification history on iPhone
Before you dive into notification history, you’ll want to make sure the feature is enabled on your iPhone. This feature is disabled by default for privacy reasons, but you can easily turn it on in your device settings. That’s it:
Step1. Open the Settings app on your iPhone.
Step2. Scroll down and tap “Notifications.”
Step3. Click the switch to allow notifications.
Once enabled, your iPhone will start tracking all the notifications you receive so you can access them later when you need them.
Access notification history on iPhone
Now you have notification history enabled. Just follow these steps to view your iPhone’s notification history:
Step1. Swipe down from the top of your iPhone screen to open Notification Center.
Step2. Instead of just browsing recent notifications, swipe up from the bottom of the screen to reveal older notifications.
Step3. Keep swiping until you reach the end of your notification history, where you will find notifications from earlier in the day or even from previous days.
By scrolling through your notification history, you can catch up on any alerts you may have missed and ensure you’re always in the loop.
How to Turn off Notifications on iPhone?
Some people are afraid of missing useful messages and need to check the iPhone’s historical notifications. But some people think the constant notifications can be distracting. Luckily, Apple allows users to close specific apps or turn off notifications entirely.
Turn off notifications for specific apps
If certain apps keep sending you notifications and you want it to be quieter, you can disable notifications for those specific apps. That’s it:
Step3. Select the app for which you want to disable notifications.
Step4. Turn off the “Allow notifications” switch.
By disabling notifications for specific apps, you can minimize distractions and only receive alerts from the apps that matter most to you.
Turn off all notifications
If you need a break from all notifications and want to temporarily silence your iPhone, you can easily turn off all notifications immediately. You need to do the following:
Step2. Scroll down and click “Do Not Disturb.”
Step3. Turn on the “Do Not Disturb” switch.
Alternatively, you can access Control Center by swiping down from the top right corner of the screen (or swiping up from the bottom on older models), then tap the crescent moon icon to enable Do Not Disturb mode.
Customize do not disturb settings
Once Do Not Disturb mode is enabled, you can further customize its settings to tailor your experience. Here are some options you can adjust:
  • Schedule: Set specific times when Do Not Disturb automatically activates.
  • Allow calls from: Choose to allow calls from everyone, anyone, or a specific contact group.
  • Allow repeat calls: Enable this feature to allow a second call from the same person within three minutes.
By customizing these settings, you can make sure important calls still get to you while avoiding other notifications.
Step Action
Turn Off Specific App Notifications Settings > Notifications > Select App > Toggle Off “Allow Notifications”
Turn Off All Notifications Settings > Do Not Disturb > Toggle On “Do Not Disturb” <br> Or, Control Center > Tap crescent moon icon
Customize Do Not Disturb Settings Settings > Do Not Disturb > Adjust settings as desired
How to Clear Notifications on iPhone?
Over time, your iPhone can accumulate too many notifications, cluttering your Notification Center and making it difficult to find important reminders.
Clear personal notifications
If you want to delete a specific notification without clearing them all, you can easily do so with just a few taps. That’s it:
Step2. Find the notification you want to clear.
Step3. Swipe left on the notification.
Step4. Click on the “Clear” option to delete the notification.
clear-personal-notifications-on-iphone
By clearing individual notifications, you can keep your notification center organized and focus on the latest updates.
Clear all notifications
If your notification center is full of notifications and you want to start over, you can quickly clear them all. In this order:
Step2. Scroll to the top of the Notification Center.
Step3. Click the “X” button next to “Notification Center” to clear all notifications.
This action will remove all notifications from your notification center, giving you a fresh working status.
How to See Cleared Notifications on iPhone
When you swipe up on the Lock screen, you can open Notification Center and view the notification history on your iPhone.
However, please note that iOS does not provide the ability to view cleared notifications. Once notifications are cleared, they will permanently disappear from Notification Center and cannot be viewed.
Tips: How to Solve the Problem of Not Receiving Notifications on iPhone?
If you encounter the problem of not receiving notifications on your iPhone, you can try the following methods to solve the problem.
1. Check notification settings: Sometimes you don’t receive notifications simply because you have turned off notification reception. Go to Settings > Notifications and select the app. Make sure the “Allow notifications” switch is turned on.
2. Check the “Do Not Disturb” mode: The “Do Not Disturb” mode works really well when we are in meetings or have something urgent to deal with. But he also suppresses notifications. You can check this by looking for the crescent moon icon in the status bar or by going to Settings > Do Not Disturb and making sure it’s turned off.
3. Restart your iPhone: Sometimes, simply restarting your iPhone can fix minor software glitches that may be causing notification issues. Press and hold the power button until the slider appears, then drag the slider to turn off the iPhone. After a few seconds, press and hold the power button again until the Apple logo appears to restart the device.
4. Update iOS: Make sure your iPhone is running the latest version of iOS. Go to Settings > General > Software Update to check for and install any available updates.
5. Check background app refresh: Make sure background app refresh is enabled for the app you want to receive notifications for. Go to Settings > General > Background App Refresh and turn it on, then make sure that specific apps are enabled as well.
6. Use AnyFix to repair your iPhone: If none of the above steps work, you can try using AnyFix for ios system repair.
When you have the problem of not receiving notifications on your iPhone, you can try to use AnyFix to fix it. AnyFix is a professional iOS system repair tool designed to help you solve various iOS problems, including notifications not working, app crashes, system running slowly, etc.
The specific operation method is as follows:
Step 1. Download AnyFix and run it on your computer > connect your iPhone to the computer > choose the System Repair.
AnyFix System Repair Option
Step 2.  Follow the guide on the screen to select the corresponding question. Then click on Start Now button.
AnyFix System Repair App Issues
Step 3. Here will list 3 modes for you to fix the iPhone issue. Click on the Standard Repair which won’t risk any data loss.
AnyFix Standard Repair
Step 4. After clicking the standard repair button, you will see the below interface. Click on the Download button.
Step 5. As the firmware download completes, you will see the below page. Click the Start Standard Repair button.
Step 6. Now, AnyFix will automatically repair your iOS device.
Repair Is Completed
Repair Is Completed
Fixing notification issues is easy with AnyFix. All you need to do is download and install the AnyFix software and follow the prompts. AnyFix will automatically scan and repair your iPhone to get your notification functionality back to normal.
FAQs about iPhone Notification History
How long do notifications stay on an iPhone?
Notifications stay on an iPhone until they are manually dismissed or cleared by the user. There is no specific time limit for how long notifications will remain visible.
Why do notifications disappear on iPhone Lock Screen?
Notifications disappear on the iPhone Lock Screen when they are dismissed by the user, or when the “Show Previews” setting is set to “When Unlocked” or “Never” in the Notification settings.
Do push notifications disappear?
Yes, push notifications can disappear if they are dismissed by the user or if they are configured to be shown only for a limited time.
In short, through the methods mentioned above, you can easily check the notification history on your iPhone. Whether you’re troubleshooting a problem, checking missed messages, or just staying informed, knowing how to access notification history can enhance your iPhone experience. So the next time you need to check a notification you may have missed, remember these simple steps to view your notification history on your iPhone.
